Possible Problems? - JeepForum.com
post #1 of 4 Old 09-19-2013, 09:07 AM Thread Starter
mort81
Possible Problems?
I have a '12 WK2 and not sure if these are problems or normal for the vehicle.
1. When mine tires spin and either the AWD or traction control kicks in I can hear moaning/grinding noise from under the dash. This only occurs at low speeds. Just want to know if anyone else experienced this and if it's a problem or just normal when the system is kicking in.
2. When the A/C is on I can here a faint clicking or humming noise coming from behind the glove box. Again is this normal with the heating and cooling system or normal? I don't notice a problem with the temp of the A/C or heat.
3. Finally, while driving I can feel a knock in my steering wheeling sometimes when turning or going over rough road. I think there is a TSB for this problem.
Any info will be appreciated. I plan on bringing these items up with the dealer but wanted to check to see if others have experienced any I these issues.
mort81 is offline
post #2 of 4 Old 12-09-2013, 10:13 AM
rs153719
I have the same issue today while driving on icy roads. When the wheels spun I got the same noise that you described. The traction control light came on for a split second
rs153719 is offline
post #3 of 4 Old 12-09-2013, 12:30 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
There is a ABS like hammer noise when traction control kicks in. Do you have QT1 or QT2 (with the mode buttons)?
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #4 of 4 Old 12-09-2013, 03:02 PM
rs153719
Base Laredo.... I guess Q1 because it's all-wheel drive with no extra functions
rs153719 is offline
