Passenger side vent - JeepForum.com
post #1 of 9 Old 03-19-2012, 07:08 PM Thread Starter
NYOverland2012
2014 WK
Passenger side vent
I used my A/c for the first time today... i noticed no air was coming out of the passenger side vent. Went to move the dial to open it and nothing. i had to stick a pen inside to open it up. Looks like its time for my first trip to the dealer!! grrrrrrr!!
NYOverland2012 is offline
post #2 of 9 Old 03-20-2012, 05:33 PM Thread Starter
NYOverland2012
2014 WK
Anyone have any idea how i can fix this myself?
post #3 of 9 Old 03-20-2012, 05:56 PM
Webb
Webb's Avatar
2012 WK
Have you try calling the dealer ?
Webb is offline
post #4 of 9 Old 03-20-2012, 07:21 PM
RichP
2011 WK
If it is one of the vents in the main stack. remove the bezel and there is an arm that connects the vents to the dial. It probably popped out.Just snap it back in. I know this because I must have knocked it out when I installed my new stereo.
RichP is offline
post #5 of 9 Old 03-21-2012, 04:09 AM Thread Starter
NYOverland2012
2014 WK
Actually it's the vent on the passenger side ... Was wondering how to get it out so I can fix it. It looks like the trim piece is holding it in.
post #6 of 9 Old 03-21-2012, 07:13 AM
RichP
2011 WK
I just looked at wk2jeeps and it looks like that is the only piece of trim they don't tell you how to remove. look for yourself, maybe I missed it.
http://www.wk2jeeps.com/interior/201...moval_001E.pdf
RichP is offline
post #7 of 9 Old 03-21-2012, 06:08 PM Thread Starter
NYOverland2012
2014 WK
You didn't miss anything...it's not there.
post #8 of 9 Old 03-22-2012, 06:56 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
I think what you are talking about is the passenger side outboard outlet. The following is from the service manual:
REMOVAL
WARNING: Disable the airbag system before attempting any steering wheel, steering column, or instrument panel component diagnosis or service. Disconnect and isolate the negative battery (ground) cable. Wait two minutes for the airbag system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the airbag system. Failure to take the proper precautions may result in accidental airbag deployment and possible serious or fatal injury.
OUTBOARD OUTLETS
NOTE: The outboard air outlets can be serviced without removing the instrument panel cover.
1. Disconnect and isolate the negative battery cable.
2. When servicing the passenger side air outlet:
a. remove the passenger side instrument panel silencer
b. remove the glove box, glove box shelf and the trim panel, located behind the glove box
3. When servicing the driver side air outlet:
a. remove the driver side instrument panel silencer
b. remove the knee blocker
NOTE: The air outlet trim panels are serviced with the air outlets as an assembly.
4. Using Trim Stick C-4755 or equivalent, disengage the retaining tabs (2) that secure the outboard air outlet trim panel to the face of the instrument panel cover (4).
5. Reach up behind the instrument panel and disengage the four retaining tabs (1 and 3) that secure each outboard air outlet (5) to the back of the instrument panel cover.
NOTE: If the foam seal on an air outlet is deformed or damaged, the seal must be replaced.
6. Remove the outboard air outlet(s) from the instrument panel cover.
JeepCares is online now
post #9 of 9 Old 03-22-2012, 05:26 PM Thread Starter
NYOverland2012
2014 WK
WOW!! That seems way too involved for me to do...i don't know if i want the dealership taking apart my dash either (never get that tight fit back). i guess i could live with it open all the time....i never sit on that side anyway....lol
Thank you for all our help.
Annoying Buzz-like sound coming from passenger side vent. Lutes WK2 Grand Cherokee Forum 11 09-19-2013 02:19 PM
Cold air coming out of driver side vent Ewrcavalier WK2 Grand Cherokee Forum 17 03-04-2013 06:00 AM
Strange AC/Vent occurance... steveinaz WK2 Grand Cherokee Forum 0 10-07-2011 06:26 AM
Vent Using Outside Air Temp jtpape WK2 Grand Cherokee Forum 5 05-06-2011 07:58 PM
Who Put The Battery Under The Passenger Seat? ram2 WK2 Grand Cherokee Forum 6 02-13-2011 10:31 AM
