Oil Leak. Dealer "drain plug is worn out" - JeepForum.com
post #1 of 40 Old 02-09-2016, 03:26 PM Thread Starter
Heyniger_Al
2012 WK
Little backstory:
2012 GC.
Aprx 68,000 miles.
I get my oil changed a little more frequently than recommended. Every 3k miles. The last time was last Wednesday, 2/3/16.
Start noticing oil on the ground after the change, take it back in, today 2/9/16.
The dealer (where I have done all my oil changes) acknowledges that everything looks normal however, there is a "visible" leak coming from the drain plug.
Diagnosis. "Drain Plug is worn out. The seal/gasket around the drain plug, where flush contact is made with the oil pan is no longer forming a good seal. I saw the technician ratchet it down and there was still a leak."
I have changed oil on many vehicles...never experienced this issue.
Service charges and fluid top of were waived but, they charged me for a new plug at $9.60 total.
Looking for anyone with a similar experience to chime in and steer me away from anything besides dealer error here. I am having a hard time believing that without gross over tightening of the drain plug, the seal would be compromised.
Also, to waive any labor/fluid charge points towards more than the dealer being nice about the inconvenience.
Heyniger_Al is offline
post #2 of 40 Old 02-09-2016, 03:29 PM
SeniorVerde
Worn out drain plug on a 2012? That's BS. Someone cranked on it a bit too hard and either stripped threads or cross threaded- since you always go to the same place, we know who that is.
SeniorVerde is offline
post #3 of 40 Old 02-09-2016, 03:48 PM Thread Starter
Heyniger_Al
2012 WK
My thought ^ exactly and I specifically made those points. They denied that the threads were stripped or cross threaded and pointed to the seal area, where the plug physically touches the outside of the oil pan as the issue.
Total bs as the threaded section actually creates the seal. 10$ but it's the dishonesty that really gets me.
post #4 of 40 Old 02-09-2016, 04:06 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Drains plugs used to have a crush washer which could be over crushed over time and reduce its sealing effectiveness. I don't think currently crush washers (or gasket) are used and the seal is built into the bolt head ... which can get over crushed. I don't think they depend on the treads for sealing. But I dunno. With all those customer appreciation oil changes, I haven't changed oil in awhile.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #5 of 40 Old 02-09-2016, 05:57 PM
TAWS600
Had something similar happen a few months back. Started noticing oil after it was changed. Not much but shouldn't be leaking anything. Took it back. Dealer said it was a bad drain plug. Thought the same thing. How does it go bad unless stripped. Couldn't prove anything, paid the $8 or so for a new plug and that fixed the problem. At the time I had about 85,000 miles. 2011 hemi. Just out of curiosity what state are you in? I would find it humorous if it was the same dealer. Maybe the same tech. It is a small world u know.
TAWS600 is offline
post #6 of 40 Old 02-09-2016, 06:00 PM
fishinbama
2007 WK
I have a box of small copper gaskets that fit various sizes of drain plugs. Every now and then I will put a new one on. I think you just needed a new crush gasket. The rubber and plastic ones wear out. A simple little round gasket.
http://www.amazon.com/gp/product/B00...=sr_1_2&sr=8-2
2007 limited crd 2wd, 3.07 ratio, GDE eco tune, dpf delete, BuilderBill valve body
2013 VW Passat tdi, 6m
2005 GMC crew cab 5.3
fishinbama is offline
post #7 of 40 Old 02-10-2016, 06:30 AM Thread Starter
Heyniger_Al
2012 WK
In northern CT
post #8 of 40 Old 02-10-2016, 02:54 PM
2kg4u
2014 WK
If you change your oil every 3,000 miles you have done 22 oil changes. That's at least double what most conservative owner's would do, or at $40 per change, an extra $400 or so to pour good oil down the drain. A $10 oil plug pales in comparison.
Roy
2014 Overland, 3.6 L
Fumoto Qwikvalve, Ionic CXV running boards, Michelin X-Ice Xi2 snow tires
2kg4u is offline
post #9 of 40 Old 02-10-2016, 04:00 PM
kryogen
2011 WK
Probably over torqued
2011 Grand Cherokee Overland V8, QD, QL
Nokian Hakkapelita 8 SUV Studded winter tires
kryogen is offline
post #10 of 40 Old 02-10-2016, 05:32 PM
ravenworks
ravenworks's Avatar
Pretty much what others have said,put a new crush washer on it.
In all honesty they should be changed frequently, per the manual.
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #11 of 40 Old 02-11-2016, 07:12 AM Thread Starter
Heyniger_Al
2012 WK
Eh, thanks for the input Roy.
post #12 of 40 Old 02-11-2016, 07:13 AM Thread Starter
Heyniger_Al
2012 WK
Thanks
post #13 of 40 Old 02-11-2016, 07:27 AM
Dabitz
2015 WK
I have a friend with a 2015 Camry that changes his oil, full synthetic, every 1,500 miles. I tried to explain... but he wouldn't listen. It's his car and money at the end of the day.
Dabitz is offline
post #14 of 40 Old 02-11-2016, 08:35 AM
hemispin
2014 WK
Bottom line - An oil pan is durable enough to withstand the "abuse" of removing and reinstalling the drain plug 22 + times. The problem is the mechanic not applying the correct torque to the plug. It must have been severely over-tightened many times. Usually drain plugs are torqued at around 25 ft-lbs. I don't know why some mechanics feel the need to tighten them so much.
hemispin is offline
post #15 of 40 Old 02-11-2016, 01:31 PM
Nonstop
Our drain plugs do not have a removable or replaceable gasket. As said it is "built in" and permanent.
I swap in a new plug once a year just for the sake of it, but do not go adding a gasket or washer to the existing plug it will only cause you more problems.
It's rare that these peticular drain plugs will fail, but it's absolutely possible to damage both the threads and the seal by over torquing. Ask any tech what the correct tqe is for a plug, it's unlikely they know and shouldn't be necessary with any experience, it's lack of respect and thought that damages drain plugs nothing else..
2000 WJ 5.2 V8
2011 WK2 V6
Nonstop is offline
