Oil change interval - JeepForum.com
post #1 of 14 Old 11-15-2015, 02:40 PM Thread Starter
FrankAN
2014 WK
Oil change interval
I am used to changing my oil on all of my vehicles at about 5 - 6000 km intervals, never more. When I went to make an apt for an oil change on my 14 Grand Cherokee with my dealer ( at about 5500 km since last oil change) dealer advised me I could wait until close to a year or just less than 10,000 km. I found that extremely strange. Checked the manual and service guide and he was right. Even the vehicle information on the dash says I am only 50% to the next oil change. I asked the dealer what kind of oil they use and it's just 5W30, not synthetic! I find this strange and confusing! Comments?
FrankAN is offline
post #2 of 14 Old 11-15-2015, 02:47 PM
tylerwhofishes
2015 WK
I guess modern times call for more modern maintenance measures. I just had the 10K service done on my Jeep. No issues and the dealer said it was normal for people to be leery of waiting so long. They assured me that with the onboard diagnostics, if anything major was going on I would have been alerted.
tylerwhofishes is offline
post #3 of 14 Old 11-15-2015, 02:48 PM
Kev M
2012 WK
Welcome to the 21st century...
Kev M is offline
post #4 of 14 Old 11-15-2015, 03:23 PM
jim_in_PA
2012 WK
Yes, the oil change intervals are more extended these days unless you are driving in certain conditions as detailed in your manual. For MY14+, you can go "up to" 10,000 miles or when your JGC's oil life display tells you to change or one year if you are a low mileage driver; whichever happens first, as long as you are doing a "normal" driving pattern as mentioned in your manual.
• 2012 JGC Summit Hemi
• 2016 Subaru Outback Limited
• 2011 Subaru Outback Limited
jim_in_PA is offline
post #5 of 14 Old 11-15-2015, 04:48 PM
stopplease
I'm curious if there is a warning indication from the EVIC? I'm at over 9,000 miles right now and will be changing it this week. I figured there maybe a warning at <10% left, but nothing yet
stopplease is offline
post #6 of 14 Old 11-15-2015, 06:04 PM
jim_in_PA
2012 WK
stopplease, yes, depending on the model year, the indication may vary, but you should get an indicator in the EVIC when you are at the point that the system expects you to get an oil change. For my MY12, the indication comes on a couple hundred miles before the 8000 mile mark hits. On MY14+, it can be by miles (10K) or engine oil life calculated by the system.
post #7 of 14 Old 11-16-2015, 07:05 AM
JeepCACares
FrankAN
Regular maintenance of your vehicle is, as you know, very important to ensuring years of enjoyment. As @jim_in_pa has mentioned, there are conditions that can result in the oil change indicator lamp illuminating sooner.
Operating conditions such as frequent short-trips, trailer tow, extremely hot or cold ambient temperatures, and E85 fuel usage will influence when the “Oil Change Required” message is displayed. Severe Operating Conditions can cause the change oil message to illuminate as early as 3,500 miles (5,600 km) since last reset.
Top Care Specialist
FCA Canada
JeepCACares is offline
post #8 of 14 Old 11-16-2015, 10:01 AM
BiLLyb0b
2014 WK
My first oil change indicator came on at ~9500 miles (conventional oil). Dealer put synthetic in there and the light came on about ~7000 miles after? I just reset the indicator and went on about my day... what do you guys think? I was going to wait for ~15,000 miles before changing it
BiLLyb0b is offline
post #9 of 14 Old 11-16-2015, 11:04 AM
lurtonk
2015 WK
Synthetic oil will last 25K + but the issue is the contaminants suspended in the oil that causes the wear.
If you use someone like Blackstone Labs, they can help you maximize your oil change interval.
lurtonk is offline
post #10 of 14 Old 11-16-2015, 12:53 PM
Kev M
2012 WK
I haven't seen the service manual so I can't say for sure, but I'm under the impression the Oil Life Monitor on our vehicles is strictly algorithm based (ECM calculated on factors like temperature, rpm, run time) and it has no way of actually directly measuring oil so it has no idea if you put in synth or dino and calculations are based on dino.
Meaning your experience just meant a change in your usage patterns.
Kev M is offline
post #11 of 14 Old 11-16-2015, 12:57 PM
stopplease
I wouldn't unless you don't care about your warranty
post #12 of 14 Old 11-16-2015, 07:20 PM
PMwk2
Why would anyone spend $40 to $50 grand on a vehicle and worry about a $30 dollar oil change. Yikes
PMwk2 is offline
post #13 of 14 Old 11-17-2015, 03:56 AM
diverb
2014 WK
I send off a sample of my oil to be analyzed each change and I have been pushing my oil changes out to 10,000 miles and my reports are good
2014 Jeep Grand Cherokee 3.0 diesel -PPEI DPF/SCR delete tune, Custom 3" down pipe, BANKS Exhaust
diverb is offline
post #14 of 14 Old 11-17-2015, 05:26 AM
kryogen
2011 WK
on my 2011 it usually pops at 6-8000 km. I do mostly short trips and half a year is very cold weather.
So I usually change the oil twice a year.
2011 Grand Cherokee Overland V8, QD, QL
Nokian Hakkapelita 8 SUV Studded winter tires
kryogen is offline
