post #1 of Old 01-01-2016, 06:51 PM Thread Starter
Jeff1119
2015 WK
Is this normal?
On my 2015 Jeep Grand Cherokee if I'm idling and press the brake pedal a few times the brake pedal becomes still as if the engine was off but once I start moving its ok again. Is this some kind of feature? Thanks
Jeff1119 is offline
post #2 of Old 01-01-2016, 07:21 PM
Fastback89
2015 WK
Our 2015 Altitude does the same thing, I think it may be using up available vacuum while idling because of a check valve. This is just my theory of mine because I don't believe anything is malfunctioning.
Fastback89 is offline
post #3 of Old 01-01-2016, 07:29 PM Thread Starter
Jeff1119
2015 WK
Yeah I don't think anything is wrong with it, have the same jeep as you do, the altitude. Appreciate the feedback. Was curious.
Jeff1119 is offline
post #4 of Old 01-01-2016, 09:31 PM
tylerwhofishes
2015 WK
Yes it is normal. You're pressurizing the brake system. The master cylinder is sending pressure to the calipers via the brake fluid. There's a vacuum line off the master cylinder that runs to somewhere in the engine.
tylerwhofishes is offline
You may not post new threads
You may not post replies
