New JGC? Check the alignment. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > New JGC? Check the alignment.
PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiFS: Jeep Fog Light LED Bulbs! Several Brightness Options! Smoking Deal on Jeep Slip Yoke Eliminator Kit with rear 13
Unread 05-17-2015, 06:58 AM   #1
richiejeep
2015 WK
We bought a new JGC (18 miles on the odometer) last week in Denver and drove it back to Texas. We both noticed the steering required constant corrections to keep it going straight down the road. Our Texas dealer did an alignment and found 6 out of ten adjustments in the unacceptable range (see below.) The dealer also said there was a year warranty on the car for alignment issues. Even if you're not noticing issues, you might want to get the alignment checked.
richiejeep is offline   Reply With Quote Quick reply to this message
Unread 05-17-2015, 09:12 AM   #2
SavageBrewer
Doesn't surprise me at all, new vehicle takes a little while for all the bushings and joints to settle in, then they get chained down during transport which can put uneven stress on the suspension. Both of my last two new vehicles needed an alignment in the first 500 to 1000 miles, in general its not a bad idea because a bad alignment will chew through tires more quickly also.
SavageBrewer is offline   Reply With Quote Quick reply to this message
Unread 05-20-2015, 10:46 AM   #3
lurtonk
Drive it like u stole it
2015 WK
My question is a what height setting should the alignment be set.
I notice on my 2015 QL that when it is parked that there appears to be a slight negative camber on the fronts.
lurtonk is online now   Reply With Quote Quick reply to this message
Unread 05-20-2015, 11:01 AM   #4
mx71
2013 WK
Whichever setting it gets driven in the most. I'm guessing you don't drive it in the park setting.
- A Jeep product
- Other vehicles
- Motorcycles
mx71 is offline   Reply With Quote Quick reply to this message
Unread 05-20-2015, 11:37 AM   #5
lurtonk
2015 WK
Wk
Aero mode most of the time but I don't know how the technician would get it in Aero mode while in P.
Unread 05-21-2015, 08:03 AM   #6
Jurassic_Jeep
2014 WK
you have a star case or reference for this 1 year alignment warranty? I think mines a little off but I've driven it for about 11500 km and not really sure if its been there since day one (it might have been?)
Jurassic_Jeep is offline   Reply With Quote Quick reply to this message
Unread 05-21-2015, 08:18 AM   #7
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Some folks seem to be guessing. FSM says:
"When checking or performing an alignment, vehicles equipped with Air Suspension (SER) must be in the manually selected "Sport" position of the terrain select switch, or the Aero mode if using a scan tool."
It goes on to provide instructions for setting the mode.
The specified alignment specs are relative to the sport mode.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote Quick reply to this message
Unread 05-21-2015, 08:21 AM   #8
lurtonk
2015 WK
So I guess the local Firestone/Goodyear can't do alignments on QL vehicles
Unread 05-21-2015, 08:30 AM   #9
ColdCase
ColdCase's Avatar
2011 WK
The Firestone dealer should have instructions from his alignment machine vendor. When he looks up the specs there should be a note to turn the terrain knob to sport mode (while the engine is running) before driving the vehicle onto the alignment machine (and turn off easy entry/exit). No special equipment needed.
Unread 05-21-2015, 08:35 AM   #10
TiggerFree
Junior Member
2015 WK
There is a mode under settings for use when aligning...
TiggerFree is offline   Reply With Quote Quick reply to this message
Unread 05-21-2015, 08:36 AM   #11
TiggerFree
Junior Member
2015 WK
oops... here is the image..
Unread 05-21-2015, 09:58 AM   #12
ColdCase
ColdCase's Avatar
2011 WK
Good point, for 2014 and newer model years.
Unread 05-21-2015, 11:15 AM   #13
Kanab_ram
2014 WK
My 2014 must have some serious negative camber issues as the inside tire tread is gone after only 20k miles. I plan to take it to the dealer at 25k for service and will have them take a look at the alignment settings. Don't know why camber would be set to anything other than zero.
2014 Limited, 3.0L diesel, 20" Bridgestone Blizzaks, Off-Road Adv II, Quadra Lift
2014 Wranger Sahara, White, Rubicon wheels and tires
Kanab_ram is offline   Reply With Quote Quick reply to this message
Unread 05-21-2015, 11:41 AM   #14
lurtonk
2015 WK
Zero camber is fine for driving in a straight line but a little negative (0-.5 degrees) will help cornering.
Unread 05-21-2015, 08:45 PM   #15
DRKRED12
You are going to drive 5,000 more miles knowing that you have an alignment issue and improper tire wear. Are the tires too far gone?
DRKRED12 is offline   Reply With Quote Quick reply to this message
