Need help finding correct part # for brake rotors. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Need help finding correct part # for brake rotors.
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great valueLast Day to take advantage of 5% off August Promo
Unread 06-20-2015, 09:19 AM   #1
spinxt
Time for new rotors up front. Can someone that can look up part numbers provide me with the correct parts for my 2014 limited with the VIN#
I need front rotors and pads. Going with the MOPAR rotors. Open to suggestions on pad brands
1C4RJFBTXEC151514
spinxt is offline   Reply With Quote Quick reply to this message
Unread 06-20-2015, 04:48 PM   #2
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Dealers and online outlets ask for your VIN so they can make sure you get the right rotors. There are only two types of front rotors, standard and HD (well there's the SRT too but whos counting). Look at your rear rotors and if they are solid, you have std brakes, if they have vents between two solid pieces, you have HD brakes.
Instead of waiting here, it may be easier to order the the one you think is right and they will check the VIN and get back to you if you happened to pick the wrong ones.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now   Reply With Quote Quick reply to this message
Unread 06-20-2015, 06:01 PM   #3
spinxt
Pretty sure I have the HDs
Unread 06-20-2015, 06:05 PM   #4
spinxt
Originally Posted by ColdCase
Dealers and online outlets ask for your VIN so they can make sure you get the right rotors. There are only two types of front rotors, standard and HD (well there's the SRT too but whos counting). Look at your rear rotors and if they are solid, you have std brakes, if they have a vents between two solid pieces, you have HD brakes. Instead of waiting here, it may be easier to order the the one you think is right and they will check the VIN and get back to you if you happened to pick the wrong ones.
Not that easy...they don't list them as "HD" or standard...they the order codes (e.g. BR1, BR6,BRY). I have no idea what those mean
Unread 06-20-2015, 07:55 PM   #5
Nonstop
As stated its as simple as, if you have vented rear rotors you have the HD brakes. Google a pic of solid vs. vented for a good comparison, makes it easy. In case you want to go from SD to HD, for $40 in brackets it's the best front brake upgrade out there. Rears too but more to it.
2000 WJ 5.2 V8 4x4...yup
2011 WK2 V6
Nonstop is offline   Reply With Quote Quick reply to this message
Unread 06-21-2015, 07:11 AM   #6
spinxt
That part I understand, I know I have the HD system. The issue is what "order" code represents the HD rotors/pads on the online retail sites. Is it BR1, BR6, or BRY??
Unread 06-21-2015, 08:43 AM   #7
Nonstop
Retail sites only ever reference 350mm or HD most I've seen just list all hemis as HD. I know it's caused problems locally. I'm talking advance,pepe boys, or autozone that I've looked.. The codes are dealer use or maybe molar parts online. Never checked. I'm 99.8675309% BR6 is the HD code, but reading the first page of one of cold cases past posts got me the accurate info, I can't search on my crapple iPad right now cause it doesn't like to be touched..
The guys at the website you order from will knock this out in one conversation, their cool about it
2011 WK2 V6
Unread 06-22-2015, 02:02 AM   #8
Kolak
Vendor
Kolak's Avatar
Which Mopar rotors have you priced? Regular or Value Line?
Any desire to go with an upgraded aftermarket rotor?
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
kolak@aol.com or kolak@kolakperformance.com
Kolak is online now   Reply With Quote Quick reply to this message
Unread 06-22-2015, 02:13 PM   #9
biker2k
2012 WK
what brackets are those
do you have part numbers on that
I have non hd brakes and would like to switch to hd at least in the front and if its just two bolt on brackets im in..
biker2k is offline   Reply With Quote Quick reply to this message
Unread 06-22-2015, 02:27 PM   #10
ColdCase
ColdCase's Avatar
2011 WK
There was a rather long thread awhile ago with all the details. I'll have to look for it later.
Well well well, lookie here, all the parts numbers one would ever need hiding in the maintenance sticky thread :
http://www.jeepforum.com/forum/f309/.../#post14917137
Unread 06-22-2015, 03:54 PM   #11
spinxt
There was a rather long thread awhile ago with all the details. I'll have to look for it later. Well well well, lookie here, all the parts numbers one would ever need hiding in the maintenance sticky thread : http://www.jeepforum.com/forum/f309/.../#post14917137
Ha ha...okay I get it...use search ;-)
Unread 06-25-2015, 11:29 AM   #12
2kg4u
2014 WK
The correct part number for your front rotors is 68035 012AB. Having said that, I would never buy rotors from the dealer. I always buy mine from rockauto.com, and I am very particular about the parts that go on my cars.
Roy
2014 Overland, 3.6 L
Fumoto Qwikvalve, Ionic CXV running boards, Michelin X-Ice Xi2 snow tires
2kg4u is offline   Reply With Quote Quick reply to this message
