Nav went from green to black - JeepForum.com
post #1 of 5 Old 12-04-2010, 07:32 AM Thread Starter
BREJOLAW
The Nav used to show the land and roads on the screen in different colors. Now the land is in all black. I can still see everything but I would rather have it back to green. Also, where do I find the instructions for the nav system in the manual?
Any suggestions?
BREJOLAW is offline
post #2 of 5 Old 12-04-2010, 07:53 AM
rlj
rlj's Avatar
I'll have to double check the correct sequence however I think if you press the "MENU" button, upper right, you then can adjust the color scheme and/or brightness by pressing another button........ if it's not a brightness issue you may have a bad unit.
2011 WK2 Overland
2007 JK Sahara Unlimited
2003 TJ X
rlj is offline
post #3 of 5 Old 12-04-2010, 09:25 AM Thread Starter
BREJOLAW
Thank you rlj. Found it and it did the trick.
BREJOLAW is offline
post #4 of 5 Old 12-04-2010, 09:51 AM
XjChris843
1997 XJ Cherokee
even tough you found the problem. isn't that what happens when night mode is activated? i know my Nav unit (garmin or what ever brand) changes the colors of the land to black when night mode is activated
97' XJ sport 4.0 - 8 inches of lift - full rusty skids - arb rear aussie front - 4.56 gears - 35X10.50 Interco Super Swamper SSRs- 16'' Cragar Soft 8 rims - wilderness roof rack - rustys steering box brace - rustys roll bar - rustys short arm intake - hack n tap SYE - YJ NP231J - trans cooler - tons of other stuff
XjChris843 is offline
post #5 of 5 Old 12-05-2010, 08:33 AM Thread Starter
BREJOLAW
That was the issue. It went to night mode somehow. I must have hit something.
BREJOLAW is offline
