NAV issue - JeepForum.com
post #1 of 11 Old 01-22-2016, 02:04 PM Thread Starter
AlDente67
2014 WK
NAV issue
SO I have one issue with the NAV. The routing always selects the best route according to how the crow flies, but that leaves a trail of zigzagging through the side streets to get from point A to B, where the highway would be ultimately quicker.
I can't find a setting that will select the 'fastest route'. Say the highway is L-shaped. The NAV will attempt to guide you through surface roads instead of sticking to the L-shape highway crossing, if that make sense.
Has anyone found a setting that will do this?
AlDente67 is offline
post #2 of 11 Old 01-22-2016, 02:06 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
There should be a routing preference screen where you can select the shortest route or fastest route, dunno off hand where that is. But when entering an address there is routing option button.
"Before Route Guidance
Before confirming the route with the “Yes” button on the touchscreen, it is possible to select options different from the default route settings.
• Options – Press the “Options” button on the touch- screen to display a list of options to alter your route. To make a selection press and release the desired setting until a check-mark appears."
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #3 of 11 Old 01-22-2016, 02:06 PM
Miami_Son
2015 WK
Set it to fastest route?
Miami_Son is offline
post #4 of 11 Old 01-22-2016, 02:10 PM Thread Starter
AlDente67
2014 WK
Originally Posted by ColdCase View Post
There should be a routing preference screen where you can select the shortest route or fastest route.
The options i see are "avoid unpaved roads, ferries, toll roads, etc" not this option.
Jeep sent me an offer to upgrade the NAV for $150 last year and I balked. This was a new download in summer of 2014, so I don't see why I should pay that much for some upgrade, but that is another matter.
post #5 of 11 Old 01-22-2016, 02:21 PM
Miami_Son
2015 WK
If you bought a nav update last year then it was probably already a couple years old. My new JGC that was built in September 2015 and purchased in November 2015 has nav maps from 2013. That's ridiculous.
post #6 of 11 Old 01-22-2016, 03:37 PM
ColdCase
ColdCase's Avatar
2011 WK
It seems that this feature has confounded many over the years. Unlike stand alone Garmins, the Jeep Nav does not give you a settings menu for routing preferences in an easy to find spot.
So the next time you enter a destination address and before confirming the route with a "Yes", press the options button and you should be able to select fastest route. That preference will stick. If you want to change it you will have to navigate back to this settings menu again
Screen Shot 2016-01-22 at 4.46.41 PM.jpg   Screen Shot 2016-01-22 at 4.48.54 PM.jpg
ColdCase is offline
post #7 of 11 Old 01-22-2016, 07:48 PM
FLHXSE3
2014 WK
I didn't see the option to go a couple kms out of the way and sneak up from the other side
FLHXSE3 is offline
post #8 of 11 Old 01-22-2016, 08:07 PM
Blackshirts
2012 WK
not to hijack but my big problem with the Jeep nav is the fact that as you cross the intersection it appears on the screen. Many times Im looking for the street name as I pull up to an intersection and it doesn't appear on the screen until I'm literally in the middle of it so I miss the turn.
Blackshirts is offline
post #9 of 11 Old 01-22-2016, 08:16 PM
ColdCase
ColdCase's Avatar
2011 WK
Well they were watching for you on this side, so the Nav snuck you around. I alway drive home a different way, just to throw them off
ColdCase is offline
post #10 of 11 Old 01-22-2016, 08:18 PM
ColdCase
ColdCase's Avatar
2011 WK
Mine has a next turn banner on the top of the screen which includes the street name (e.g "Day Street" with an arrow), sometimes the street name shows up in the center turn by turn display. I forget how to turn that on and off....
ColdCase is offline
post #11 of 11 Old 01-23-2016, 10:50 AM
bottlerocket91
Why no option for only dirt roads?
bottlerocket91 is offline
