Multiple failures on rear shocks 2011 Overland - JeepForum.com
post #1 of 2 Old 04-27-2013, 09:56 AM Thread Starter
Watcher58
Angry Multiple failures on rear shocks 2011 Overland
A few months ago, I got the rattle-squeek curse that seemed to be from the left rear shock and was consistent with the TSB's on the shocks and shock mount problems. I've made 5 trips to the dealer, which in rural MT is a 100 mile round trip each time. The first failure was in the left rear, the second was in the left rear(I could reach through the rim, grab the shock and move it back and forth and the right rear shock was covered with oil)) and now on the third set of shocks (within 10 weeks) the left rear is leaking oil very badly. By badly, I mean it leaves a puddle of oil on the ground. It has been doing that for about a week. There is a coating of oil on the shock going up under the dust cover . the oil actually drips off the lower mounting bolt. They finally replaced the upper shock mounts when they installed this last set. Needless to say, I am ready for blood. Is there any magic solution someone knows about?? The TSB describes the issue but doesn't say they can't fix it-ever. This has been 3 sets of new shocks-not the repair crap they came up with. I'm also suspicious that the left rear has failed every single time. Help!! expectives deleted
Watcher58 is offline
post #2 of 2 Old 04-27-2013, 11:27 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
A bad batch of replacement shocks? I think there has been a couple part number revs. If the dealer can't get you the newest rev level.. you can buy them on line ~$50. It may be less trouble swapping them yourself than dealing with the dealer...
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
