Mturo's white wk2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Mturo's white wk2
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAttention to the TJ owners 1996-2006 NEW LED LIGHT OPTIONSBds fox ipf 2.0 racing series shocks now available at rock
Unread 03-23-2013, 09:01 PM   #1
mturo
Well my plans continue to change for what I want to do to the jeep. I finally ordered some parts, and was going to order wheels and tires as well this week but decided to hold off on that.
aFe stage 2 dry intake
Gibson axle back exhaust
My thoughts on the intake and exhaust:
Drone from exhaust is very minimal in the cab, the exhaust kinda fills in the noise where the intake is quiet. MPG change is still to be determined.
****For anybody who installs intake themselves be very careful when removing sensor they are very fragile and plastic. I snapped mine when trying to pull it out, luckily they only cost $18 (had to call a few dealerships to find one in stock though).
2012 Stone White WK2 Laredo 4x4
mturo is offline   Reply With Quote
Unread 03-23-2013, 11:49 PM   #2
Jackal01
Jackal01's Avatar
2012 WK
Looks good. What are the plans for wheels and tires? Anything else? Did you order the exhaust from Quadratec?
'12 Laredo V6 ORA1|Terra Grappler 265-70-17|MB TKO 17x8.5|Silverstar Ultra low beams|Mopar Front and Rear WK2 slush mats|RRO 2.5" lift
BWoody extended sway bar links|K&N 77 Series Intake|Gibson Exhaust | Viair OBA | RRO Combo Winch mount| Q9000S winch
Jackal01 is offline   Reply With Quote
Unread 03-24-2013, 06:05 AM   #3
mturo
Not sure what future plans are now, my family is taking delivery of a new raptor Thursday so I might pour some money into that bad boy lol. But wheel and tire I will probably end up with similar to you on mb tko's but in 18's wrapped 265/65/18. I ordered the exhaust from autoanything.
Unread 03-24-2013, 06:21 AM   #4
Jackal01
Jackal01's Avatar
2012 WK
........a Raptor. I would give a testicle for one. Lucky man!
Sent from my underground lair.
Unread 03-24-2013, 06:27 AM   #5
mturo
haha i will post some pics of it once it is here, any tips or suggestions for the exhaust install? I know you said you had some issues aligning yours think it would be better to just pay to have it installed? I have all the tools to do it, just dont want to mess it up.
Unread 03-24-2013, 07:42 AM   #6
Jackal01
Jackal01's Avatar
2012 WK
If you have a cut off wheel use that. I just didn't get the saw straight enough. From my prospective it lookedlike it though. The hangers I had to lube ups a lot then pried them out. If you're patient go for it otherwise just pay to have our done.
Unread 03-24-2013, 05:04 PM   #7
mturo
Decided I hated the aFe badge that was slightly angled, so I pulled it off.
Unread 03-25-2013, 11:15 PM   #8
SPL170db
That actually looks to be the best designed cold air intake I've seen so far for the WK2. Pulls from the front air snorkel, blocks off most of the rest of the engine compartment and uses plastic tubing instead of metal. Maybe I'll chuck my Airraid and get that one instead.
SPL170db is offline   Reply With Quote
Unread 03-26-2013, 06:26 AM   #9
mturo
Tubing is actually metal but its texture/finish is almost a perfect match the factory engine cover.
Unread 03-26-2013, 02:19 PM   #10
mturo
Installed exhaust today, decided just to take it to a shop and get it welded up so there are no leaks will take pick when I get home
Unread 03-26-2013, 02:39 PM   #11
Jackal01
Jackal01's Avatar
2012 WK
Did you get the stainless or aluminum exhaust?
Edit: Aluminized
Unread 03-26-2013, 02:51 PM   #12
mturo
I got the stainless, didnt feel like spending the extra cash on aluminum.
Unread 03-26-2013, 02:53 PM   #13
boyvan
2012 WK
Just curious to know other than looks.....if there are other differences between the two?
Stainless looks good.
_______________________________
2012 JGC Overland - Max Steel
boyvan is offline   Reply With Quote
Unread 03-26-2013, 03:43 PM   #14
Jackal01
Jackal01's Avatar
2012 WK
Interesting. Quadratec has Aluminized for $240 and Stainless for $322. I would have gotten Stainless if they had it when I placed the order so it could have been welded. Oh well. Maybe I should have looked at Autoanything
Looks good. At least yours is centered unlike mine
Unread 03-26-2013, 04:00 PM   #15
mturo
Ok wow I got confused and feel stupid now, I bought the one that was aluminized steel not stainless. Yours can be welded because it's steel not aluminum.
The price I paid for mine was I think 220.
