Mounting Fire Extinguisher Help - JeepForum.com
post #1 of 5 Old 11-22-2011, 03:19 PM Thread Starter
Buffy
2012 WK
I found a neat, 3 lbs chrome fire ext that I want to mount on the left rear panel above the rear wheel. (see pic #1)
The panel is made of that thick plastic (poly-whatever you call it!) and I need some advice on how to mount it to the panel.
The back of the extinquisher has 6 mounting holes that are pretty well spaced out, but what will hold in the plastic? - Sheetmetal screws, etc.
Any help would be greatly appreciated....
PIC #1 Where I want it....
PIC #2 What I thinkl it will look like.....
Buffy is offline
post #2 of 5 Old 11-22-2011, 04:30 PM
fljeepleo
2011 WK
Take the panel off and mount with either a backing plate or even easier use bolts with large washers. You don't want some loose cargo hanging up on it and one of those screws pull out or worse crack the panel.
I'd use some large washers to distribute the load. IMO.
2011 Stone White Grand Cherokee Laredo E, ORA1, QT2, Factory Trailer Tow, 3m FX 15% Tint.
Retired Jeeps
1998 Wrangler Sahara 10inch skyjacker lift, 38x14.50 TSL
2005 Grand Cherokee Limited, 5.7, QD2
fljeepleo is offline
post #3 of 5 Old 11-22-2011, 04:51 PM Thread Starter
Buffy
2012 WK
I would LOVE to get behind the panel, but I have looked and looked and looked and I'll be darned if I can figure out how it comes off.
Buffy is offline
post #4 of 5 Old 11-22-2011, 08:11 PM Thread Starter
Buffy
2012 WK
I found a PDF file that shows how to remove the panel, but WOW, it is more involved than I thought! I may have to rethink the location of the extinguisher...........
Buffy is offline
post #5 of 5 Old 11-22-2011, 09:25 PM
Murcus
2009 JK Wrangler
I recently took an interest in this as well.
Let us know what you try out.
I know there are also some hitch mounting options with a gas can.
Murcus is offline
Ideas for Mounting TV Monitors in the 2011? getoutandplay WK2 Grand Cherokee Forum 14 11-08-2013 05:53 PM
Radar Detector Mounting rdlarado10 WK2 Grand Cherokee Forum 19 06-26-2013 08:50 AM
Brake Controller mounting location Santac WK2 Grand Cherokee Forum 2 06-27-2011 10:01 AM
Roof Rack Mounting process wjs81866 WK2 Grand Cherokee Forum 9 04-24-2011 07:20 PM
Mounting Radar Detectors in the Overland john07slade WK2 Grand Cherokee Forum 2 12-17-2010 01:43 PM
