mopar rock sliders 82212157 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > mopar rock sliders 82212157
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 01-07-2015, 11:15 PM   #1
metalic5
2014 WK
whats every ones takes on these, i'm thinking of putting them on a 2014 billet silver overland diesel. just want peoples opinion on how they think they would look.
p.s. if anyone has a pic of theirs with them share it please, would love to see a billet silver overland with them, but cant seem to find any pictures online.
thanks,
metalic5 is offline   Reply With Quote Quick reply to this message
Unread 01-08-2015, 07:11 AM   #2
canistel
2012 WK
Just do a google image search:
canistel is online now   Reply With Quote Quick reply to this message
Unread 01-08-2015, 07:16 AM   #3
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
There are links to both mopar an rr sliders and tube bars in the modification thread sticky... Black ones however. There may be a chrome photo in the picture thread.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote Quick reply to this message
Unread 01-08-2015, 07:56 AM   #4
DirtEmax-USMC
What's the largest tire you can run on these jeeps. Those look aftermarket
Also how much are the RR sliders
Sent from AutoGuide.com Free App
DirtEmax-USMC is offline   Reply With Quote Quick reply to this message
Unread 01-08-2015, 09:11 AM   #5
ColdCase
ColdCase's Avatar
2011 WK
Check the wheel and tire fitment sticky thread and other wheel and tire sticky threads for discussion. The answer depends of tire manufacture and model, wheel backspacing, how much fender you want to trim and bend and your definition of fit. Details are in the threads, discussed often.
Unread 01-08-2015, 03:07 PM   #6
ferntree
ferntree's Avatar
2014 WK
They are a really solid bit of gear and a PIA to fit. Ended up getting the dealer to fit them before we took delivery.
They also come in handy in a tight parking space. I put the Jeep into OR2 for the a$$hats who open their doors wide.
2014 Overland Oiler, ORII, QD, Granite/Indigo Blue, rock rails, Cooper AT3's - oh yeah!!
Officer, these handcuffs are tight!
Just relax, they're new. They'll stretch after you wear them a while....
ferntree is offline   Reply With Quote Quick reply to this message
Unread 01-08-2015, 07:31 PM   #7
gabbagabba
2014 WK
Ditto, solid rock rails, took my dealer a lot of time to get them on and then I had to bring it back b/c they caused some mild body damage in the process. So they are not "bolt on", if you r buying for looks or as a step dont bother, if you need for off road then yes they are hard core. To do it over prob would have gone with RROutfitters ones. also, they are not true powder coated and sand and pebbles from the tires take the textured paint off pretty easily. The dealer touched them up with bedliner which has held up worse. I will likely recoat them myself in the spring.
gabbagabba is offline   Reply With Quote Quick reply to this message
Unread 01-09-2015, 10:31 AM   #8
eibyer
I have the trailhawk rails and love it. No tube on the side to stick out (no door ding protection though) but definitely a must and some skid plates if you go out on rocky trails.
eibyer is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 11:37 AM   #9
robvasi
2015 WK
Protection from rocks
I plan to take my Jeep on unimproved roads. Before I knew rock rails existed, I purchased the chrome step rails as shown in the picture.
Is there is a way to add something that would protect the sides from rock damage?
Or should I replace these rails for something else?
There is no replacement for displacement
robvasi is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 06:53 PM   #10
spinxt
Originally Posted by robvasi
I plan to take my Jeep on unimproved roads. Before I knew rock rails existed, I purchased the chrome step rails as shown in the picture. Is there is a way to add something that would protect the sides from rock damage? Or should I replace these rails for something else?
I think you answered your own question here....rock rails are what you need. Those side steps may end up doing more damage if if you high center than not having anything there at all.
spinxt is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 07:04 PM   #11
robvasi
2015 WK
I just don't myself taking my new Jeep on a road that there is a potential to high-center. I will be on unimproved road and sand, going through washouts, to get to places to make photographs. So, I suppose there is always a potential, but I can always turn around if the hazard is significant.
I need to clarify what I meant by 'rock damage.' I was not referring to large rock that my Jeep is traversing, but to small rocks that are kicked up from the tires. I will have mud flaps installed tomorrow, are those enough?
Unread 03-27-2015, 09:53 AM   #12
ferntree
ferntree's Avatar
2014 WK
You don't need them.......'till you need 'em!!
Unread 03-27-2015, 10:32 AM   #13
robvasi
2015 WK
This falls in the category of "I wish I would have"
Is there a way to install the rock rails and also the side rails like I have now?
Unread 03-27-2015, 10:36 AM   #14
spinxt
This falls in the category of "I wish I would have" Is there a way to install the rock rails and also the side rails like I have now?
No, unless you're a master fabricator. The rock rails cover the pinch weld and any mounting location that the running boards would mount to.
If you get the normal rock rails (not trail hawk version), they have w tube that extends out that offers additional protection and acts as a step.
Unread 03-27-2015, 10:49 AM   #15
gooberphx420
If you have any buddies in the welding / metalworking business, I'm sure you could fab up some screens/filler panels pretty easily that share the same bolt holes as the steps.
gooberphx420 is online now   Reply With Quote Quick reply to this message
