Mopar CAI - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Mopar CAI
End of Summer Sale, 20% OFF!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRough Country Jeep Suspension Deals at Rockridge 4WD!
Unread 09-08-2012, 10:32 PM   #1
GU3R086
Mopar CAI
Hey guys, wondering if anyone has tried out the mopar cold air intake? I asked my parts guys and they said they haven't seen any yet. K&N has one available, but I'm not really crazy about an oiled filter. I'd rather have a dry element. Thoughts?
Thanks,
G
GU3R086 is offline   Reply With Quote
Unread 09-09-2012, 12:14 AM   #2
Jackal01
Jackal01's Avatar
2011 JK Wrangler
aFe makes a CAI for WK2.
2011 Billet JKUS
Jackal01 is offline   Reply With Quote
Unread 09-09-2012, 07:49 AM   #3
peckmv
I have the Mopar CAI. I installed it myself and its easy. I had to do it to make room for the catch can I installed. Its well made and gives a throaty sound when you push the throttle. The only thing that I had to rig myself was a strap to hold the upper radiator hose. I used the stock bracket and a heavy duty wire tie and it worked great. I bought it on ebay from Steve White Motors. They are a Jeep dealer that has below list pricing.
peckmv is offline   Reply With Quote
Unread 09-09-2012, 07:54 AM   #4
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Volant makes a better dry filter CAI for the WK2. Several here have them. It has a more enclosed airbox which probably takes less hot air from the engine compartment than others.
Search the forum for CAI and you should find several recent discussion.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote
Unread 09-09-2012, 08:25 AM   #5
padgett
2012 WK
Motor Parts CAI is only available for the Hemi, 77070042 for V6 is still "delayed".
One of these is a turbo diesel.
We take in orphans. Notary Sojac y'all.
padgett is offline   Reply With Quote
Unread 09-09-2012, 08:45 AM   #6
GU3R086
Haha well that explains why I couldn't find one yet. Thanks for the info guys, I will look around at some of the other options.
Unread 09-09-2012, 09:49 AM   #7
GU3R086
So K&N has a system out for a couple hundred bucks. I had a K&N on my Harley with no problems, but I'm scared to damage my motor. Not with dirt but with oil. I feel like its impossible not to suck some of that oil into the system.
Unread 09-09-2012, 01:39 PM   #8
Matterhorn
2012 WK
Save your money, most CAI are not worth their price.
Matterhorn is offline   Reply With Quote
Unread 09-09-2012, 04:08 PM   #9
ColdCase
ColdCase's Avatar
2011 WK
Yes, until there is a tuner, CAIs only gives you more engine sound.
Unread 09-09-2012, 04:13 PM   #10
peckmv
Agreed. I felt no increase in anything. My reason was for catch can space.
Unread 09-09-2012, 08:24 PM   #11
padgett
2012 WK
Well I would hope for a drop in the IAT temp if the resonators/radiators were removed from the hose. I typically see 120-140F on a 90F day and that is too hot. 100F is pleanty for the computer to run right (I live in a hot climate) and cooler denser intake air reduces the likelihood of detonation & P0300/302.
Unread 09-09-2012, 10:15 PM   #12
ColdCase
ColdCase's Avatar
2011 WK
These CAIs are not really effective in bringing any cooler air into the engine than the stock system. So you can hope for a temperature drop, but you won't see it. Moving the IAT sensor can trick the engine into thinking the air is cooler, but I've read here that it doesn't make much if any difference anyway.
I haven't read here often of misfires and detonations and codes being set, except in the case of the defective V6 head. But even that may be due to running a higher concentration of ethanol than you may think, at least in the US. The concentration of ethanol seems to vary all over the place and as soon as we get rid of that mistake, we will all be better off.
Unread 09-10-2012, 06:18 AM   #13
dizz1979
2012 WK
I have the Mopar CAI. It was easy to install, and the Hemi has an incredible throaty sound now. Would do it again in a heartbeat. The Mopar, hands down is the best quality of all the intakes I have seen.
dizz1979 is offline   Reply With Quote
Unread 09-10-2012, 10:34 AM   #14
padgett
2012 WK
Agree Hemi probably does not change much, is only about a foot from the filter. The WK2 Pentastar OTOH is about three feet long and has both resonators and furnaces. At 80-90F ambient I often see 120-140F IAT (and it matches ambient closely when engine is cold so sensor is reasonably accurate). The filter design is good with its own box and an intake from in front of the radiator. It is the "hose" that should be able to run at no more than 10F above ambient at cruise.
Carbs need warm air, a good FI doesn't.
Unread 09-10-2012, 06:40 PM   #15
GU3R086
Check this out
I think the 3.6 sounds pretty mean. K&N has 35% off the retail price when ordered direct. On top of it, as much as I want more mopar, I don't know that I want a bunch of chrome under the hood when everything else is black.
