Modification, Maintenance, Repair, and Build Write Ups - Page 5 -
Go Back > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Modification, Maintenance, Repair, and Build Write Ups
Summer is Over! Time for a saleIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineIron Rock Offroad products - get them from Kolak!
Unread 03-17-2014, 09:02 AM   #61
Finally completed the install except for the front trim. I need to do some minor adjustments when I get the time but overall happy with the result. I'm happy with the TH version, the extra bit that extends out from the body rubs on my pants already. The tube one would probably drive me nuts, but it does give the extra ding protection.
The flag bolts need a better way of being secured, the push nuts are not gonna cut it and will eventually lead to someone messing up when it's time to push the rail up to the body. The last bolt on the pinch weld closest to the front of the body is the most annoying one to install. Grrr
eibyer is offline   Reply With Quote Quick reply to this message
Unread 03-18-2014, 08:27 AM   #62
Had a few minutes to make a rough cut on the plastic trim. It still needs some sanding/filing until it fits nicely. Some pics after being cut and trimmed with a dremel.
Unread 03-18-2014, 02:54 PM   #63
like to see the finished product. thanks for sharing
JMP8562 is offline   Reply With Quote Quick reply to this message
Unread 03-21-2014, 10:16 AM   #64
Sad to say I think there will be no finished product. I agree with fwdjeep's comment about the poor design. If the plastic trim is cut to how they have it in the install instructions, there's about 3/4" of the front of the skid plate that is visible. It looks tacky, probably better leave it off and just cover the hole with something else. You can see it in this video.. -- he did a better job at trimming his but still leaves parts exposed.
Unread 06-06-2014, 02:30 AM   #65
2013 WK
Originally Posted by damascusHEMI View Post
The Corsa mufflers are tucked up tight and since we painted them black, you really can't see them. The sound is fantastic...I took it on a 8 hour round trip recently for the Virginia Tech vs. MD game. I can barely hear the rumble while cruising without load, however it roars when you get on it. Very nice. Take a look -
How much
Last edited by Jackal01; 06-06-2014 at 06:13 AM.. Reason: No point in quoting pictures.
KickRocks is offline   Reply With Quote Quick reply to this message
Unread 06-26-2014, 12:20 PM   #66
2013 WK
Wow, that is Purdy!!!!
Originally Posted by 14summithemi View Post
Many thanks to the team at Corsa Performance (TMG Performance Products) for working with me and agreeing to do this special run. This will use the current Product #14457 (3.0" Cat-Back, Dual Rear Exit with Single 4.0" Polished Pro-Series Tips) that fits the 2011-2014 Jeep Grand Cherokee 5.7L V8 MODIFIED with a different exit/bend out of the mufflers using 2 round tips per muffler staggered to better fit the rounded contour (see pics). Product # and ordering info TBD per below.
First, let me assure everyone I get zippo from this deal (I paid for my exhaust) I am just being the front man since I was first and live next to HQ. Please run all questions through me at this point. If you call Corsa, he will just direct you to me….thx
Looking to know who is willing to step forward and speak for one of the initial systems. I am looking for those who WILL BUY and those who are JUST INTERESTED. If you need to do research, decide, ect…then you are JUST INTERESTED which is great too. If you would be placing the order right now if you could then you are a WILL BUY. Just trying to see what the initial pool of buyers and prospects looks like so Corsa can decide the size of the first run.
To respond either reply to this thread or PM me. Either way, your spot on the WILL BUY list will be confirmed by return PM. To ensure the WILL BUYS get their systems the order info will only be sent by PM that way no one gets boned.
This is also posted on Jeep Garage Dot Org under the same title. I will combine the lists so please only reply on one forum.
Per Corsa…On a group buy of 10 the cost is $1597.50 each + shipping + ZERO TAX (In and out of Ohio). Once an order of 10 is ready to be placed it will take about 2 weeks lead time (Could be 3 pending work load in engineering/production at the time). It is a one box system that is about 98 lbs and some change, Shipping is expected to be around $75-105 flat depending on location, residential vs. business address, etc…The group buy would be run through one of Corsa’s nearby (Berea, OH) accounts to handle cc processing etc…The ordering contact info would be PM’d to the WILL BUY forum members.
As of 2/7/14 I have (7) WILL BUY folks. Those (7) should have a PM from me. Let’s see what the numbers look like through Sunday 2/16/14. Should have at least (10) by then. That would mean you could have it by St. Patty’s Day or so.
The Volant CAI is not included in this group buy. Pics below, videos at links below.
EASE OF INSTALL? Corsa will install for FREE at their facility in Berea, OH (really!). Or go here:
FLOW? Average of 97% gain over stock
WHAT’S IN THE BOX? Everything needed to complete the installation is included. Each system includes the mufflers, pipes, hangars, 304SS Polished Tips you choose and all of the necessary instructions and information for installation.
PERFORMANCE? Performance varies by the vehicle and system chosen. On average, CORSA systems will deliver a 3-5% increase in horsepower, though this may vary by vehicle. For example, our Corvette systems will see in average increase of 17-19 HP increases with the addition of our full cat-back system. In addition to HP increases, CORSA systems will dramatically increase free-air-flow, allowing your other performance modifications to achieve their full performance potential.
WEIGHT REDUCTION? 13 lbs. lighter than stock
DRONE? CORSA's Patented RSC® Technology is designed for an AGGRESSIVE SOUND under acceleration and a DRONE-FREE EXPERIENCE
WARRANTY? Your current stock exhaust: None! Corsa: Limited LIFETIME warranty for as long as you own your vehicle with proof of purchase.
MY 2 CENTS? It sounds awesome when you want it to but is civil otherwise. It is the least droning system you can get, virtually zero except when MDS kicks in you get a little drone but it goes away. All exhaust mods affect an engine’s power delivery. The Corsa takes a small bit off your 0-60 times but really perks up your rolling “punch”. It has a really cool feedback snarl when you stomp it and the tranny shifts. Heads snap when I hit it. Pretty funny. Gas mileage impact? Well, never mind that’s not the point.
Stock, 2.5", galvanized
Corsa, 3.0", all 300 series stainless
Magnaflow, 2.5", 400 series stainless pipes, 300 tips
Flowmaster 2.5", 400 series stainless pipes, 300 tips
Gibson, 2.25", 400 series stainless pipes, 300 tips
Borla, 2.5", all 300 series stainless
SO WHAT? The reason most use 2.5 is not (according to their tech support) because it is better for backpressure/hp/torque but because the larger diameter creates too large a sound wave internally creating too aggressive a sounding exhaust and unacceptable interior noise (drone). This is the RSC patent Corsa has for noise cancelling to deal with the bigger sound waves from the larger pipe diameter. Regarding the 300 vs. 400 stainless composition. For the consumer 300 series is better. It has no (or very little) iron so it resists rust/corrosion the best but is more expensive to make and harder to bend. 400 series is best for the manufacturer. It is softer and easier to mandrel bend and cheaper. They mitigate it's surface rusting by using it in the undercarriage/non-visisble areas and use 300 in the visible tips and sometimes post/end muffler if visible. I guess the 400 series has more iron in it that when it goes thru its initial heat/tempering cycle in use the iron comes to the surface and forms surface only rust. Looks bad but supposedly will not rust out internally.
YouTube video of "Thunder runs"
YouTube video of "0 - 60 run Inside"
YouTube video of Startup, Idel, Rev
Tom from Walla Walla, WA
2013 Jeep Grand Cherokee Altitude Hemi-Maximum Steel
2010 Dodge Challenger R/T w/6 spd-B5 Blue
(yes, I love Mopar and Hemi's!!)
2013hemijp is offline   Reply With Quote Quick reply to this message
Unread 07-27-2014, 08:29 PM   #67
Originally Posted by 100thdeuce View Post
It looks like in this pic the exhaust has some rather radical welded turns in the pipes. Is it just the angle of the pic or is it that severe? I can't imagine that would flow very well.
Also, I've been looking online and there seems to be two different kits. One is 14457 and one is 14466. Is one of these what you installed?
I was thinking the same thing on those sharp angled welded offsets. Did corsa improve on this yet? I know this is an old post post, but I think for non SRT wk2, we would pick the one ending in 57.
MikeD73USA is offline   Reply With Quote Quick reply to this message
Unread 05-08-2015, 10:36 AM   #68
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Radio Firmware Updates
You can get some help here:
You can download the updated firmware here:
Also this site provides updates and grace notes:
The following info has been posted on many forums for years, and used to be on the mygig site before it disappeared:
MyDrive - Ihr Schweizer Online-Speicher (
username: mygig@soxag
password: gasolio
1) Use the link above and use the login information supplied.
2) Go to the My gig folder and find the applicable software up for your radio.
3) Download the ISO file
4) Burn the ISO image onto DVD
5) Insert the DVD into your radio and it will ask you if you want to update to the newer version.
You can also use a USB stick instead of a DVD.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote Quick reply to this message
In order to be able to post messages on the forums, you must first register.
Jeep, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. is not in any way associated with Jeep or the Chrysler Corp.
