Modification, Maintenance, Repair, and Build Write Ups - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Modification, Maintenance, Repair, and Build Write Ups
The Cure for your Tie Rod Roll!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineOffset Tie Rod Kit From RuffStuff!
Unread 01-14-2014, 12:32 PM   #46
2kg4u
2014 WK
I don't like that exhaust at all. If I were you, I would rip it off right now. I will provide you with an address to send it to just so it's not cluttering up your garage.
Roy
2014 Overland, 3.6 L
Fumoto Qwikvalve, Ionic CXV running boards, Michelin X-Ice Xi2 snow tires
2kg4u is offline   Reply With Quote Quick reply to this message
Unread 01-15-2014, 09:29 AM   #47
14summithemi
2014 WK
Hmmm, No! It is sweet tho, ain't it?
14summithemi is offline   Reply With Quote Quick reply to this message
Unread 01-16-2014, 07:40 PM   #48
952_JGC
2014 WK
14summithemi, Thought I saw on another thread someone using an aftermarket, cat back Hemi exhaust on a V6...wonder if your stock summit Hemi exhaust would fit a '14 V6...I like the look of exhaust on the summits better than other models...you had the rectangle/trapezoid shaped tips right?
_______________________________________________________________
2014 JGC Overland Black/Black - 20x9 Replicas with Stock Tires - WeatherTechs
Future: 17" winter wheel/tire set up - black out some of the chrome bits
952_JGC is offline   Reply With Quote Quick reply to this message
Unread 01-17-2014, 04:29 AM   #49
14summithemi
2014 WK
Ya, I like the dual tip per side too...yes, stock was trapezoid that exactly mirrored the bumper skirt cutout...RE the V6, don't know but cannot imagine it works, V6 has each head collecting into a y pipe near engine/tranny and different bends from there but if they dualed the V6 I guess anyone with a shop/welder and some skills could pull it off, would think there would be some relevant tune/power issues to contend with given the huge change in backpressure, etc....never doubt what a "jeeper" can or will pull off
Unread 01-30-2014, 10:15 AM   #50
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Fascia Grille removal PDF
PS: I will be working on doing an index at the beginning exactly how my build thread is setup so people can click the link with the title instead of search all the pages. May take me a while.
2011 Billet JKUS
Last edited by Jackal01; 01-30-2014 at 10:17 AM.. Reason: PS: I will be working on doing an index at the beginning exactly how my build thread is setup so people can click the link wi
Jackal01 is offline   Reply With Quote Quick reply to this message
Unread 02-04-2014, 02:55 PM   #51
timsen
No one reported the OEM Mopar running boards yet?
timsen is offline   Reply With Quote Quick reply to this message
Unread 03-10-2014, 07:55 AM   #52
eibyer
I haven't seen a TH rock rail installed, so here's one half lol, that's what I accomplished on a Sunday Same install as the one with the tubes.
eibyer is offline   Reply With Quote Quick reply to this message
Unread 03-10-2014, 08:05 AM   #53
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Where did you get them?
2011 Billet JKUS
Unread 03-10-2014, 08:24 AM   #54
eibyer
Ordered it online from Mopar One, best price I could find even with the through-the-roof shipping, still cheaper than my local dealers. I like the stock look
Unread 03-11-2014, 07:55 PM   #55
eibyer
The front part of the rail is what I need to work on next where the plastic trim had to be riveted to. The hole on the left is not lined up, I will have to inspect the other side when I get to installing it on the weekend. Pic below.
Unread 03-14-2014, 09:43 PM   #56
volvite
I like the looks of TH rock rails. Keeps the lines of the Jeep while also protecting it.
Proud member of PETA= People for Eating Tasty Animals
RC X-seris 4 inch lift/32 Inch tires/My Build: http://www.jeepforum.com/forum/f197/...hread-1158910/
08 Nissan Pathfinder LE
volvite is offline   Reply With Quote Quick reply to this message
Unread 03-15-2014, 02:47 PM   #57
fwdjeep
2013 WK
I too want to cover this area
Very poor desigh by Jeep for their Rock Rails
Would like to see how you cover and protect this area
fwdjeep
Alais Scott
Mount Cotton Queensland
Australia
fwdjeep is offline   Reply With Quote Quick reply to this message
Unread 03-16-2014, 12:21 PM   #58
spinxt
Originally Posted by fwdjeep
I too want to cover this area Very poor desigh by Jeep for their Rock Rails Would like to see how you cover and protect this area
I don't understand this comment. The Mopar rails are more protective than any others on the market. Aside from some installation challenges, I don't see any issues.
spinxt is offline   Reply With Quote Quick reply to this message
Unread 03-16-2014, 03:20 PM   #59
fwdjeep
2013 WK
Rock rails very good protection to sills
But the front area in the wheel arch area is total unprotected and i can see sand and mud being pushed into the gaps in this area and causing issues in the future.
Woudl like to cover this area to give protection of gaps
fwdjeep
Alais Scott
Australia
Unread 03-17-2014, 05:02 AM   #60
JMP8562
yes I agree
89 lifted wrangler to 95 lifted cherokee to 01 GC now 07 JK 4 DOOR X WITH HIGH ROCK FRONT WINCH BUMPER APPROACH ROLLERS/WARN 9.5TI WINCH WITH UNDER THE HOOD CUT-OFF SWITCH/2.5" SS lift/1"M.O.R.E BL/33" BFG KM2 ON STOCK 17"/RIVER RAIDER ROCKER GUARDS-SLIDERS/OFF ROAD HEROS FASTBACK SOFT TOP/GIBSON DUEL EXHAUST/CUSTOM MADE TRUNK/HELLA FF300/HELLA500 W-WINDSHIELD MOUNTS/DELTA SKYBAR/CARBON FIBER DASH KIT/DUEL AND SINGLE GUAGE PODS WITH VOLT-OIL PRESSURE-OIL TEMP GUAGES/COBRA 75 CB/AND A LOT OF RECOVERY GEAR
JMP8562 is offline   Reply With Quote Quick reply to this message
