Looking at a 2012 GC Overland w/Hemi -which 4WD system? - JeepForum.com
post #1 of 8 Old 12-03-2013, 02:37 PM Thread Starter
shudog
2012 WK
I'm thinking it should have the Quadradrive 2 since it's a Hemi Overland. That would be the only option, right? Is there any way to tell?
Previously owned jeeps:
'06 Grand Cherokee Limited w/4.7L V8 & QD2
'98 Grand Cherokee Limited w/5.2L V8 & Quadra Trac - sold at 230k miles
shudog is offline
post #2 of 8 Old 12-03-2013, 03:48 PM
LibGrandCher
2012 WK
This page should have what you are looking for...
http://wk2jeeps.com/2012/2012_wk2_specifications.pdf
LibGrandCher is offline
post #3 of 8 Old 12-03-2013, 04:32 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
When you press the start button, a drawing of a WK2 and "QuadraDrive" appear in the EVIC for at least a few seconds.
In 2011 the ELSD was standard on all Overland V8s but in 2012 I think it was standard only on the Summit; It was included with the V8 Off-Road Adventure II Group on any model, however. At least thats what this page says, and they are typically accurate: http://wk2jeeps.com/wk2_2012_features.htm
ELSD makes a QTII into a QDII. You can also crawl under the rear end and look for an electric motor hanging off the driver's side of the diff housing. The electric motor drives the clutches.
If the 2012 Overland has the ORA II option package it should also have trail rated badge(s) and probably 18 inch wheels.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #4 of 8 Old 12-03-2013, 06:10 PM Thread Starter
shudog
2012 WK
^thanks a ton. I don't want the ORA II package or the 18" wheels. Gotta have the 20's. That option list is pretty damn confusing but it basically confirms what I thought, if it's got the Hemi, it's got the Quadradrive. I'll doublecheck & look underneath to make sure.
shudog is offline
post #5 of 8 Old 12-05-2013, 05:04 PM
phil385
2014 WK
No technically the Hemi has nothing to do with it. On a 2012 if it has 20's only the Summit has Quadradrive. If it has 18's it has ORA II which obviously has QD. A V8 Overland with 20's can still only have QT.
2014 SRT: Redline 2, Black Spiders
phil385 is offline
post #6 of 8 Old 12-08-2013, 06:54 PM Thread Starter
shudog
2012 WK
Well as confusing as all that is, I ended up getting this vehicle Saturday. I couldn't tell by looking underneath if the rear diff had the ELSD or not, no real obvious electric motor, looks the same as any other differential to me... but the startup screen on the dash says "Quadradrive" so that's good enough for me.
shudog is offline
post #7 of 8 Old 12-08-2013, 08:41 PM
ColdCase
ColdCase's Avatar
2011 WK
There has been a lot of wheel swapping, so a used WK2 with 20 inch wheels may or may not have come from the factory that way.
ColdCase is offline
post #8 of 8 Old 12-10-2013, 03:01 PM
2kg4u
2014 WK
If you PM your VIN and email address to me, I will email you a complete factory build sheet for your vehicle. That way you will know for sure what your vehicle was originally equiped with. Of course, you can get it from Chrysler as well, but it may take a few days.
Roy
2014 Overland, 3.6 L
Fumoto Qwikvalve, Ionic CXV running boards, Michelin X-Ice Xi2 snow tires
2kg4u is offline
