Listening to Pandora via bluetooth - JeepForum.com
post #1 of 33 Old 01-01-2012, 05:12 PM Thread Starter
billybronco1
2011 WK
Can you listen the streaming music using the bluetooth in the 2011 GC instead of plugging into the aux input?
billybronco1 is offline
post #2 of 33 Old 01-01-2012, 05:23 PM
WvTaco
2011 WK
i have the 430n and a iphone4s i stream slacker radio with no problem and the other 4000 songs on my phone. u just have to pair it.
WvTaco is offline
post #3 of 33 Old 01-01-2012, 11:04 PM
Steelear
2005 WK
Works on the 730n as well
Steelear is offline
post #4 of 33 Old 01-02-2012, 12:06 AM
SPL170db
......and for what its worth, Slacker is 10x better than Pandora.
SPL170db is offline
post #5 of 33 Old 01-02-2012, 05:09 AM Thread Starter
billybronco1
2011 WK
I have the 730N and the phone is paired to the radio and works fine as a phone. How do I play streaming music with bluetooth
post #6 of 33 Old 01-02-2012, 06:30 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
On the radio aux screen select devices, select your phone from the list, let it connect (may take two tries). On your phone play your music.
ColdCase is offline
post #7 of 33 Old 01-02-2012, 07:11 AM Thread Starter
billybronco1
2011 WK
I'm technically challenged I do not see any list on the AUX screen, really does not let me change anything
post #8 of 33 Old 01-02-2012, 07:16 AM Thread Starter
billybronco1
2011 WK
If there is nothing plugged in to AUX I can't do anything - if I just plug the cable in to AUX it says auxiliary devices are available but I can't add anything or see a list - if I plug the phone in music comes out of the radio
post #9 of 33 Old 01-02-2012, 08:55 AM
lords47
Oh my god I'm so happy I read this thread!! Lol. Got it to work via Bluetooth on my 430n radio. Thanks for the tip!
2014 Grand Cherokee Overland - Billet Silver/black - 4x4 - Hemi
lords47 is offline
post #10 of 33 Old 01-02-2012, 08:56 AM
WvTaco
2011 WK
with phone paired, i go to i thinhk media the button under radio. and a soft button usually takes a second or two then u can push the aux it the third soft button to the right. then either hit play from phone of the radio. i perfer to control by phone.
WvTaco is offline
post #11 of 33 Old 01-02-2012, 12:46 PM Thread Starter
billybronco1
2011 WK
my AUX does not light up (is grayed) so its not functional unless I plug a wire into the external AUX plug - I'm lost! If I go to blue tooth on my phone it sits there spinning on the devices line. Blue tooth phone works fine in the car
post #12 of 33 Old 01-02-2012, 12:54 PM
Greg012GCO
2012 WK
make sure your phone is already paired via bluetooth. then go to am/fm/aux and hit aux. you should be able to pair your phone. then all music audio on your phone should stream to the system's speakers. there will be no controls on the screen except pause, but the steering wheel buttons do some stuff, like advance to the next song, and volume. sound is excellent.
Greg012GCO is offline
post #13 of 33 Old 01-02-2012, 01:02 PM Thread Starter
billybronco1
2011 WK
When you said "paired" you only pair it once right? Like its paired and the uconnect phone works fine but I can not get any life out of the AUX button - does nothing
post #14 of 33 Old 01-02-2012, 01:39 PM
skremese
2012 WK
What phone do you have?
skremese is offline
post #15 of 33 Old 01-02-2012, 01:43 PM
ColdCase
ColdCase's Avatar
2011 WK
What kind of phone? Devices can pair as either a phone or an entertainment device or both. When you pair a typical phone, it usually does both types of pairing at the same time.
You can tell from the pairing listed when you go to system set up and pairing menu. It should list all the devices that you have paired, including your phone. There are two icons on the left of the device name, one looks like a phone the other music. You will only be able to connect to the phone for playing media if the entertainment icon is shown (may have an red X through it because its not connected).
You may have to set up your phone to stream over bluetooth, delete the current pairing from the radio and pair again. If the phone gets paired as an entertainment device, it will show up in the aux menu as a device to select, otherwise it won't and you will have phone calls only.
I'm sure you would have noticed, but my phone always asks me if it OK to connect to the radio, and unless you acknowledge, it doesn't connect. So make sure you respond to all prompts on the phone.
ColdCase is offline
Volume on bluetooth at MAX tmcmons WK2 Grand Cherokee Forum 19 11-05-2012 04:47 AM
UConnect Bluetooth basalamah WK2 Grand Cherokee Forum 0 12-31-2011 12:02 AM
Pandora Streaming superserialMBP WK2 Grand Cherokee Forum 8 12-30-2011 09:04 AM
Pairing Iphone 4gs with JGC Bluetooth Prav WK2 Grand Cherokee Forum 5 10-24-2011 08:02 AM
730 & Droid X Bluetooth issues ISurvivedNMU WK2 Grand Cherokee Forum 2 07-16-2011 06:06 PM
