-   WK2 Grand Cherokee Forum (http://www.jeepforum.com/forum/f309/)
-   -   Listening to Pandora via bluetooth (http://www.jeepforum.com/forum/f309/listening-pandora-via-bluetooth-1308507/)
billybronco1 01-01-2012 05:12 PM
Can you listen the streaming music using the bluetooth in the 2011 GC instead of plugging into the aux input?
WvTaco 01-01-2012 05:23 PM
i have the 430n and a iphone4s i stream slacker radio with no problem and the other 4000 songs on my phone. u just have to pair it.
Steelear 01-01-2012 11:04 PM
Works on the 730n as well
SPL170db 01-02-2012 12:06 AM
......and for what its worth, Slacker is 10x better than Pandora.
billybronco1 01-02-2012 05:09 AM
I have the 730N and the phone is paired to the radio and works fine as a phone. How do I play streaming music with bluetooth
ColdCase 01-02-2012 06:30 AM
On the radio aux screen select devices, select your phone from the list, let it connect (may take two tries). On your phone play your music.
billybronco1 01-02-2012 07:11 AM
I'm technically challenged I do not see any list on the AUX screen, really does not let me change anything
billybronco1 01-02-2012 07:16 AM
If there is nothing plugged in to AUX I can't do anything - if I just plug the cable in to AUX it says auxiliary devices are available but I can't add anything or see a list - if I plug the phone in music comes out of the radio
lords47 01-02-2012 08:55 AM
Oh my god I'm so happy I read this thread!! Lol. Got it to work via Bluetooth on my 430n radio. Thanks for the tip!
WvTaco 01-02-2012 08:56 AM
with phone paired, i go to i thinhk media the button under radio. and a soft button usually takes a second or two then u can push the aux it the third soft button to the right. then either hit play from phone of the radio. i perfer to control by phone.
billybronco1 01-02-2012 12:46 PM
my AUX does not light up (is grayed) so its not functional unless I plug a wire into the external AUX plug - I'm lost! If I go to blue tooth on my phone it sits there spinning on the devices line. Blue tooth phone works fine in the car
Greg012GCO 01-02-2012 12:54 PM
make sure your phone is already paired via bluetooth. then go to am/fm/aux and hit aux. you should be able to pair your phone. then all music audio on your phone should stream to the system's speakers. there will be no controls on the screen except pause, but the steering wheel buttons do some stuff, like advance to the next song, and volume. sound is excellent.
billybronco1 01-02-2012 01:02 PM
When you said "paired" you only pair it once right? Like its paired and the uconnect phone works fine but I can not get any life out of the AUX button - does nothing
skremese 01-02-2012 01:39 PM
What phone do you have?
ColdCase 01-02-2012 01:43 PM
What kind of phone? Devices can pair as either a phone or an entertainment device or both. When you pair a typical phone, it usually does both types of pairing at the same time.
You can tell from the pairing listed when you go to system set up and pairing menu. It should list all the devices that you have paired, including your phone. There are two icons on the left of the device name, one looks like a phone the other music. You will only be able to connect to the phone for playing media if the entertainment icon is shown (may have an red X through it because its not connected).
You may have to set up your phone to stream over bluetooth, delete the current pairing from the radio and pair again. If the phone gets paired as an entertainment device, it will show up in the aux menu as a device to select, otherwise it won't and you will have phone calls only.
I'm sure you would have noticed, but my phone always asks me if it OK to connect to the radio, and unless you acknowledge, it doesn't connect. So make sure you respond to all prompts on the phone.
The time now is 04:00 AM.
