Limited "Skips" laterally over bumps? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Limited "Skips" laterally over bumps?
JEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFFAlloy usa heavy duty ball joint kitsROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail
Unread 06-30-2014, 07:00 AM   #1
redddog
Does anyone experience this? It seems at speeds over say, 35 mph, if I go over pot holes, sewer covers or bumps, I get what seems like a lateral skip or jump to either the right or left. It's pretty un-nerving.
Anyone else get this?
It seems like it happens more on the right side and only in the back but that could just be my imagination.
Any ideas why or what this could be? I've resisted until now to bring it in because I can guarantee the "oh yeah, that's normal" response.
It's a stock LTD with no tow (thus no SLS shocks) and with Destination ATs on there.
redddog is offline   Reply With Quote Quick reply to this message
Unread 06-30-2014, 08:54 AM   #2
EvgeshaIS300
check your tire PSI, when shipped its at 40 or so for transportation reasons. At that setting many reported sliding around just like yours.
You need to dial it down to 33-36
EvgeshaIS300 is offline   Reply With Quote Quick reply to this message
Unread 06-30-2014, 08:56 AM   #3
icetech
I keep mine at 35psi and i get that same exact thing... horrible vehicle.
icetech is offline   Reply With Quote Quick reply to this message
Unread 06-30-2014, 09:17 AM   #4
redddog
yeah. I'm at 34-36 usually.
So this is normal?
Unread 06-30-2014, 12:14 PM   #5
chowner
2014 WK
chowner is offline   Reply With Quote Quick reply to this message
Unread 06-30-2014, 12:15 PM   #6
46er
2014 WK
Tire pressure PSI setting is on the driver door; mine says 36 cold. I haven't noticed anything that I would consider un-nerving; LTD, no trailer or OR pkg. It doesn't change direction, just stays where its pointed. You might have something loose in the back, like a shock; I'd have it checked.
2014 Grand Cherokee Limited, BD 3-14, MDH 031503, V6, QTII, nav, sun roof, fold flat pass seat
46er is offline   Reply With Quote Quick reply to this message
Unread 06-30-2014, 01:18 PM   #7
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
The WK2 has a light truck suspension which is a bit stiffer and provides more feedback than a typical car... which are more like pillows.
If you don't like the stiffness, you can try dialing down the tire pressure to 33 or so. It may take enough edge off for you. When you haul heavy, pump the tires up to 36.
If the Jeep is unnerving to drive, get it checked out ASAP. there could be something loose.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote Quick reply to this message
Unread 06-30-2014, 01:50 PM   #8
Bullheadbud
2014 WK
I have a 2014 GC Lmtd, 4x4, Penstastar. Running stock Goodyears at about 34 lbs. No skipping. Handles excellent. Drivin it from AZ. to WA. state and back.
Bullheadbud is offline   Reply With Quote Quick reply to this message
Unread 06-30-2014, 04:17 PM   #9
smljeep
2014 WK
I have a '14 limited ecodiesel and actually think the suspension is a little soft so I'm running 39 PSI.
I don't experience and lateral jumping around going over potholes etc.
Eddie
Building high performance custom homes at Smith Mt. lake, VA!
www.PDandM.com
smljeep is offline   Reply With Quote Quick reply to this message
Unread 06-30-2014, 05:23 PM   #10
Dave2002ti
2012 WK
Tires
Could be the crappy Firestone Destination ATs. You running a third rate AT tire on your GC. The combined spring rate of your GC and the spring rate of your tires could be causing your problem. Yeah tires have a spring rate.
Dave2002ti is offline   Reply With Quote Quick reply to this message
Unread 06-30-2014, 06:56 PM   #11
kagmcp1
2014 WK
No, that is not normal at all. You didn't mention the year or mileage or whether it still has original tires or not. As most have already advised, I would suspect tires first and possibly worn shocks. If is a 2014 go to the dealer and test drive one of theirs first. My Limited has easily been the best handling and driving SUV I have ever owned.
kagmcp1 is offline   Reply With Quote Quick reply to this message
Unread 06-30-2014, 10:50 PM   #12
polizei
To a certain extent it's normal, at least in my experience with multiple vehicles.
2014: RRO 2.5" Lift, 32" LT275/65/18 Nitto Terra Grapplers, Pro-Comp 7089, XenonDepot HID Kit
polizei is offline   Reply With Quote Quick reply to this message
Unread 07-01-2014, 12:12 AM   #13
wk2gp
2012 WK
Dave2002ti is correct and redddog JGC is a 2014 LTD
wk2gp is offline   Reply With Quote Quick reply to this message
Unread 07-01-2014, 06:48 AM   #14
redddog
Wow. Not even second rate. All the way down to the third rate.
This is the first of that opinion on the Destination ATs. I've also owned them on 3 other trucks and never experienced anything like that at all. They've been my favorite tire for years.
I'd highly doubt, and it has been my direct experience, that a properly inflated, highly regarded tire would be the issue.
Maybe you could expand a bit on your theory?
Guess I'll go in for a "yeah, that's totally normal" later today.
Unread 07-01-2014, 06:51 AM   #15
redddog
2014 JGC LTD, 2000 miles. And apparently 3rd rate crappy Destination ATs.
