Lifting a WK2 with a Hi-Lift jack - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Lifting a WK2 with a Hi-Lift jack
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! The Ruffstuff 9" Disc Brake brackets!Even Better Heim Pricing! From Ruffstuff
Unread 11-17-2013, 04:37 PM   #1
spinxt
..you know I've been kicking around the idea of getting the RR roof rack kit. While researching on their website, I noticed they sell an attachment for a hi-lift jack and that got me thinking.
Where would you even put a hi-lift to lift a WK2???
spinxt is offline   Reply With Quote Quick reply to this message
Unread 11-17-2013, 06:13 PM   #2
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
You can get the wheel attachment and lift from a wheel.
You can lift from the hitch.
Or you can lift from the rock rails if you have aftermarket ones installed.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline   Reply With Quote Quick reply to this message
Unread 11-17-2013, 06:36 PM   #3
jake22si
2014 WK
Kinda sad you can't use a highlift on a stock jeep anymore, oh well
jake22si is offline   Reply With Quote Quick reply to this message
Unread 11-17-2013, 08:07 PM   #4
spinxt
What about the MOPAR rock rails? I'm installing those this coming weekend....
Unread 11-18-2013, 06:00 PM   #5
MartyA
2012 WK
I haven't tried it but the mopar rock rails should have no issue as a jacking point. You'll want to do something with the top of the jack so it doesn't tip in...
Or don't get stuck ;-)
MartyA is offline   Reply With Quote Quick reply to this message
Unread 11-18-2013, 10:07 PM   #6
WhiteOut
WhiteOut's Avatar
Why? A Hi-Lift has pretty much no use on a rig (other than to be dangerous), in 6 years I have used mine once. and that was only because I dropped both rear coils at the same time.
Rather use the stock bottle jack or an X-Jack. Faster and safer.
Using one on the rear hitch might cause an issue with the rear bumper cover depending on clearance, same with the rock rails. The jack might sit a bit too close to the body for comfort.
WhiteOut is offline   Reply With Quote Quick reply to this message
Unread 11-19-2013, 08:04 AM   #7
ArloGuthroJeep
Mr. Hyde!
No argument there - they are scary to use. Especially since most people store them on the outside of their Jeep and they barely work when in good condition, add a weathered hi-lift to the picture and they hardly work. A can of grease should be standard issue with each hi-lift
Unread 11-19-2013, 11:53 AM   #8
LouC
2007 WK
Well none of the stock Grands or even XJs were able to be lifted with a high lift unless they had rock rails. Only Jeeps with separate frames (Wrangler only for a long long time now) could be lifted with out some kind of rock rails.
When I use my floor jack at home I fabbed up a couple of wooden blocks from 2x6s that I put on the saddle of the jack, that keeps it from dinging up the frame where you can use a floor jack. I'd like a lightweight but strong scissors jack that could be used for the same purpose, maybe you could run it with a rechargeable electric impact gun for lazy folks LOL....
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline   Reply With Quote Quick reply to this message
Unread 11-19-2013, 08:18 PM   #9
jake22si
2014 WK
I'm not talking about in a garage on a concrete floor, I'm talking about in the woods, in knee deep mud. A scissor or bottle jack probably wouldn't cut it. Kinda why its a "hi-lift" jack.
Unread 11-19-2013, 08:32 PM   #10
WhiteOut
WhiteOut's Avatar
If you're “knee deep” in mud with a WK2, a Hi-Lift won't do anything either lol
Sent from AutoGuide.com App
Unread 11-19-2013, 09:17 PM   #11
jake22si
2014 WK
Haha, I know. I've never wheeled anything with much plastic on it. But they are handy and it would be possible to use it as a winch if you had hooks
Unread 11-26-2013, 03:58 PM   #12
Rider2205
2014 WK
Hi-Lift Lack LM-100 Lift-Mate. $35 item that allows you to lift from the wheel. (I had lift points welded onto the frame of my old Isuzu Trooper in South Africa, but not a good option on a new GC!)
Rider2205 is offline   Reply With Quote Quick reply to this message
Unread 11-27-2013, 09:37 AM   #13
kkreit01
Even with rock rails, I would think the handle would hit the doors -- which wouldn't be good. It would be for "looks-only", and that would be silly. Buy a 6t+ bottle jack.
kkreit01 is offline   Reply With Quote Quick reply to this message
