Key FOB memory - JeepForum.com
post #1 of 4 Old 11-27-2011, 05:26 PM Thread Starter
Nonaspirin
2012 WK
Key FOB memory
I read the manual and watched a video but I still can't get the keys to Store the memory position.
Has anyone else had any difficulties? As far as I know you hit the lock button on key fob, then hit your stored memory position 1 or 2.
Thanks for any help!
Nonaspirin is offline
post #2 of 4 Old 11-27-2011, 06:38 PM
rudeney
2014 WK
I think you have it backward - you set the memory and then press the lock button on the RKE fob (see steps 7 - 10):
1. Insert the ignition key, and turn the ignition switch to the ON position.
2. Press the driver door MEMORY button number 1 if you are setting the memory for driver 1, or button number 2 if you are setting the memory for driver 2. The system will recall any stored settings. Wait for the system to complete the memory recall before continuing to Step 3.
3. Adjust the driver’s seat, recliner, and driver’s sideview mirror to the desired positions.
4. Adjust the power steering column tilt and telescoping position (if equipped) to the desired positions.
5. Turn on the radio and set the radio station presets (up to 12 AM and 12 FM stations can be set).
6. Turn the ignition switch to the LOCK position and remove the key.
7. Press and release the S (SET) button located on the driver’s door.
8. Within five seconds, press and release MEMORY button 1 or 2 on the driver’s door. The next step must be
performed within five seconds if you desire to also use a RKE transmitter to recall memory positions.
9. Press and release the LOCK button on one of the RKE transmitters.
10. Insert the ignition key, and turn the ignition switch to the ON position.
rudeney is offline
post #3 of 4 Old 11-27-2011, 07:24 PM Thread Starter
Nonaspirin
2012 WK
Ahh, makes sense now. Ok I did it backwards or was trying to many things at once. I wonder if you change setting in car does it update the key?
Thanks for quick response!
post #4 of 4 Old 11-29-2011, 10:26 PM
rudeney
2014 WK
I believe it does - whatever is stored in the linked memory position is what will be recalled when the key is used.
rudeney is offline
