Key detection problem - JeepForum.com
post #1 of 13 Old 08-09-2011, 04:25 PM Thread Starter
GatorMike
2011 WK
Have had about 4 instances in the past week where a passenger opens the door with the Jeep running and then I get the message that the Key has left the vehicle, when it has not. After opening and closing both the passenger and driver side doors a couple of times I've been able to clear the message. Any idea what's causing this? Thanks in advance!
GatorMike is offline
post #2 of 13 Old 08-09-2011, 07:12 PM
JoeSchmoe007
I had exactly the same problem once. Also had "key is not detected" when trying to start the car multiple times.
There is TSB that I hope will fix this - I plan to get it done:
http://www.wk2jeeps.com/tsb/tsb_wk2_0802411a.pdf
JoeSchmoe007 is offline
post #3 of 13 Old 08-10-2011, 02:33 PM Thread Starter
GatorMike
2011 WK
Greatly appreciate the info! Anybody found another way to clear this message, other than opening and closling the doors?
post #4 of 13 Old 08-28-2011, 05:02 PM
rlj
rlj's Avatar
Mine did this a few months back, dealer ordered a new key and issue was solved. It's a key issue.
2011 WK2 Overland
2007 JK Sahara Unlimited
2003 TJ X
rlj is offline
post #5 of 13 Old 08-28-2011, 09:19 PM
hur1ey02
2014 JK Wrangler
hit unlock on your fob.. that always recognizes it for me.
Current - 2014 Wrangler Sport; Past- 2011 WK2 Laredo X; 2008 JKU Sahara; 2004 TJ RME
hur1ey02 is offline
post #6 of 13 Old 09-01-2011, 07:42 PM
mchassler
2011 WK
I switched key fobs when it started to not recognize... I'd be in the car with the key in my hand and it would indicate that it wasn't detected.
mchassler is offline
post #7 of 13 Old 10-07-2011, 09:19 PM
rudeney
2014 WK
Last Sunday, after our first week of ownership, my wife called while out shopping and said the Jeep wouldn't start. The message "key not detected" was on the MFD, even though the key was in her purse on the passenger seat. She tried placoing the key next to the START button, but no luck. I told her to use the fob to lock and unlock the doors and that triggered it to work. Then, every other day, this same thing happened. Yesterday morning, it seemed nothing we did would get it to recognize the key to start. One time when pressing the START button, I saw the message "Remote start not possible" on the MFD. I finally did something to get it started and took it to the dealer. They kept it overnight and were able to duplicate the problem. They fixed it by reprogramming the keys and the car electronics. Oddly enough, ours is a June 2011 build, and the referenced bulletin above notes that it's only for April and earlier builds. I hope what they did was a permanent fix.
rudeney is offline
post #8 of 13 Old 04-10-2013, 03:09 PM
bobbyjo
2011 XJ Cherokee
I have a 2011 Jeep Grand Cherokee and have problems with key recognition from day one when I purchased it brand new from the dealer. I consistantly have issues where the key is not recognized and a sensor says that the key has left the vehicle. Obviously it has not, and this happens while I am driving, in park, sitting at a light, etc. Now it has happened when using the remote start, I cannot enter the car or unlock the door, and once inside, the sensor goes off, with the alarm and I cannot turn the car off or get the alarm to stop for several minutes. I brought it to the dealer again (this is #8) and they say it is just the battery in my key fob. But they have the wrong key - this one wasn't the one we had in the car at the time. They have exchanged one key fob, reset the sensor numerous times, changed key battery and it keeps happening. I need help...any suggestions?
bobbyjo is offline
post #9 of 13 Old 04-10-2013, 04:14 PM
gabbagabba
2014 WK
go to a new dealer. I went through the same song and dance with my 2011, took it there like 5 times, and then took it somewhere else for an oil change and they fixed it on the spot. said the other guys did not reprogram it right? no issues since
gabbagabba is offline
post #10 of 13 Old 04-11-2013, 11:19 PM
SPL170db
Goes without saying but in addition to the TSBs also be sure to keep a fresh battery in the fob
SPL170db is offline
post #11 of 13 Old 04-24-2013, 10:15 AM
Trespasser
Also, don't forget you can pop the start button off and insert the key physically! I've had to do that on rare occasion when it glitches out.
My issue with Enter-N-Go is sometimes it takes 5 seconds to recognize I've left the car when I try to lock it from the outside button. I just stand there like an idiot hitting the button again and again until it locks. Dealer gave me a new set of keys a while back, but now that it has started up again and I'm out of warranty I just deal with it.
Trespasser is offline
post #12 of 13 Old 04-27-2013, 07:29 PM
tubbyzj
1990 XJ Cherokee
Just happen to me the dealer had lost the keys so they programmed one key today I went to get my second key now the new key does work with the push button thank god I read on the thread about the button coming out an being able to start
Its an 87
tubbyzj is offline
post #13 of 13 Old 04-27-2013, 07:29 PM
tubbyzj
1990 XJ Cherokee
But the remote works locks an unlocks an starts the car just doesn't work with push start or button on doors
Its an 87
tubbyzj is offline
problem with seat Osubeaver WK2 Grand Cherokee Forum 13 08-17-2011 01:34 PM
Radiator Problem Zirdi WK2 Grand Cherokee Forum 5 07-30-2011 05:22 PM
Problem in 4th and 5th gear daniele767676 WK2 Grand Cherokee Forum 5 07-10-2011 01:56 PM
ACC, blind spot detection, crosspath detect pkg chiscoe WK2 Grand Cherokee Forum 4 02-23-2011 02:44 AM
