Key Battery Low... - JeepForum.com
post #1 of 21 Old 11-25-2011, 08:28 PM Thread Starter
camaro307
2011 WK
Key Battery Low...
After only 5 months of having my 2011 Laredo 4x4, the "Key Battery Low" has popped up in the main display menu. Anyone else have this pop up yet? I expected this to last longer, but I guess the remote start that I use often has drained it faster.
I wonder if it's covered in the warranty...
camaro307 is offline
post #2 of 21 Old 11-26-2011, 10:43 AM
IRSmart
2015 KL Cherokee
the battery would be about $2 from walmart. why worry if it's covered under warranty??
IRSmart is offline
post #3 of 21 Old 11-26-2011, 10:50 AM Thread Starter
camaro307
2011 WK
Wal-Mart sells 2011 JGC Key batteries?!
post #4 of 21 Old 11-26-2011, 01:21 PM Thread Starter
camaro307
2011 WK
There are also no screws, or anything to take the battery out, even with the key removed.
post #5 of 21 Old 12-02-2011, 05:16 PM
Brady12
Anybody else have info, my fob died after 9 mos and I cannot figure how to get to a battery inside
Brady12 is offline
post #6 of 21 Old 12-02-2011, 09:01 PM
efrench515
2012 WK
Basically take out the emergency key, use it to pry the case apart. The instructions are in the owners manual starting on page 27. Here is a quote from it:
1. Remove the emergency key by sliding the mechanical
latch at the top of the RKE transmitter sideways with
your thumb and then pull the key out with your other
hand
2. Insert the tip of the emergency key or a #2 flat blade
screwdriver into the slot and gently pry the two halves of
the RKE transmitter apart. Make sure not to damage the
seal during removal.
3. Remove and replace the battery. When replacing the
battery, match the + sign on the battery to the + sign on
the inside of the battery clip, located on the back cover.
Avoid touching the new battery with your fingers. Skin
oils may cause battery deterioration. If you touch a
battery, clean it with rubbing alcohol.
2012 Grand Cherokee Laredo X 4x4 ORAP2, Mineral Grey/Black Leather
2011 Buick Lucerne CXL Premium, Cyber Grey/Tan Leather
efrench515 is offline
post #7 of 21 Old 12-02-2011, 10:49 PM
Brady12
Thx
Brady12 is offline
post #8 of 21 Old 12-06-2011, 03:32 PM
IRSmart
2015 KL Cherokee
it's just a watch battery
IRSmart is offline
post #9 of 21 Old 11-18-2013, 07:14 PM
cserr1
Guest
Posts: n/a
I don't know about opening it up. I got a JGC Limited and the power port inside the little console shows a picture of a key and 12V DC as if you can charge the key in that port, but the key does not go in and the port is deeper. Also in my manual it says nothing about replacing a battery.
post #10 of 21 Old 11-19-2013, 08:48 AM
kkreit01
The 11-13 used a CR 2032. I can buy a 3-pack at the Dollar Tree (Sunbeam brand).
kkreit01 is offline
post #11 of 21 Old 11-19-2013, 01:38 PM
giantsfan18
please tell me this is a joke
giantsfan18 is offline
post #12 of 21 Old 12-13-2013, 01:57 PM
ableeda
That's a hilarious misunderstanding. Those key icons are an amazing idea though, quite useful to know whether you'll drain/kill your battery by leaving something plugged in.
ableeda is offline
post #13 of 21 Old 12-13-2013, 04:21 PM
hemispin
2014 WK
You can get 10 CR-2032 batteries on ebay for about $5. That's too cheap to not have them on hand.
hemispin is offline
post #14 of 21 Old 12-13-2013, 09:16 PM
HackFabrication
HackFabrication's Avatar
1976 CJ5
My 2011 GC kills the key fob batteries every six or so months. There are a couple good you tube videos on how to replace them.
"In the end...It's all Hack."
HackFabrication is online now
post #15 of 21 Old 12-16-2013, 09:12 AM
JorgenJGC
2011 WK
Can anyone confirm that you don't have to resync the key with the car when replacing the battery? I only have one fob for my GC and don't want to buy a battery then find out I can't restart the car since I don't have a second key to sync the original back with.
JorgenJGC is offline
