Just chirped tires in 2nd - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Just chirped tires in 2nd
Stainless Steel Door Hinge PinsPoly Door Hinge BushingsJK Front Lower Adjustable Control Arms!
Unread 04-02-2014, 02:25 PM   #1
Shub45
Was turning the corner and went from shifting first to second head straight and the transmission downshifted before going into second and chirped the tires. I know some very fast cars can do that but the a Grand Cherokee. WTF
Shub45 is offline   Reply With Quote
Unread 04-02-2014, 03:04 PM   #2
Bullheadbud
2014 WK
My 2013 Ram C.C. with 6 speed does that all the time even with a 400 lb. load of weight in the bed for winter traction.
Bullheadbud is online now   Reply With Quote
Unread 04-02-2014, 05:32 PM   #3
MattXJ
2014 WK
That thing got a Hemi in it?
89 XJ (Ltd): RE 3.5", full leafs, 3/4" coil spacers, RE monotubes, JKS Adj trac, tcase drop, OME steering stab., BFG AT 31x10.5xR15s on 15x8 3.75bs, Borla cat-back
14 WK2 SRT: DiabloSport catch can, Borla S-Type
MattXJ is offline   Reply With Quote
Unread 04-02-2014, 06:00 PM   #4
Shub45
Yes it has the hemi but I almost went through the windshield and I was up shifting.
Unread 04-02-2014, 06:11 PM   #5
mx71
2013 WK
It's a lot easier to chirp when turning. Tires generally are losing traction the tighter you turn.
mx71 is offline   Reply With Quote
Unread 04-02-2014, 06:48 PM   #6
Shub45
No I made the turn and was going straight in 1st, shifted into second and it downshifted before going into second and chirped. I know,'1st is the lowest but it did it.
Unread 04-02-2014, 06:59 PM   #7
kagmcp1
Are you sure your transmission doesn't need an update???? Just kidding, new JGC on the way. First one
kagmcp1 is online now   Reply With Quote
Unread 04-03-2014, 06:53 AM   #8
hemispin
2014 WK
Originally Posted by Shub45 View Post
....was going straight in 1st, shifted into second and it downshifted BACK TO FIRST before going into second AGAIN and chirped.
^^ I added a few words in bold. Is this what you mean?
hemispin is offline   Reply With Quote
Unread 04-03-2014, 07:04 AM   #9
Shub45
I was going quick in 1st went to shift into second and the jeep hesitated through me forward and then shifted into second. That's went the tires chirped.
Unread 04-03-2014, 07:36 AM   #10
kkreit01
2wd? -- and your tires are worn?
kkreit01 is offline   Reply With Quote
Unread 04-03-2014, 10:11 AM   #11
Shub45
4 wheel. Tires brand new. Has something to do with the transmission. Must be an update for it. It
Unread 04-03-2014, 06:43 PM   #12
BobsWK2
2014 WK
You probably ran over a banana peel or a spot of oil.
2014 Summit 4X4 V8
BobsWK2 is offline   Reply With Quote
Unread 04-03-2014, 07:06 PM   #13
Shub45
Ok smart asses. It did it again. Shifting from 1st to second it totally drops for a second then shifts really hard into second and chirped.
Unread 04-03-2014, 07:13 PM   #14
kagmcp1
I was goofing around, but it sounds like an update could be needed, did you say what year it is?
Unread 04-03-2014, 07:39 PM   #15
Shub45
2014. I havnt any updates done. I have one recall and possibly break booster since I'm an early build. Waiting til July for it all to get done. Waiting for answer on my sunroof . It's been 7000 miles and no answer yet.
