Jump start battery pack for diesel GC (2015)? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Jump start battery pack for diesel GC (2015)?
You Pick the Size and Style of Lift Kit. We will Find you FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectDynoMax fall rebate on select mufflers!
Unread 08-29-2015, 07:07 AM   #1
jeep-rambler
I have jump start battery packs in all our cars, and they've saved my butt twice on both the minivan over the years. I doubt I'd ever need one for the GrChr, but just in case, I'd like to get one...
Unfortunately, I can't seem to get a straight answer from Jeep (neither FA "support", nor the dealership) as to the CCA (cold-cranking amps) requirements for a jump start battery pack for a diesel GC (2015 year model)... My guess is that a standard baseline wimpy car pack (300 CCA) would be nowhere near enough power to jump this bad boy...
One dealership parts dept said he "thinks" the battery is a 800 Amp battery! But would that be peak or sustained cranking amps?
Anyone have any info or suggestions? Thanks in advance!
jeep-rambler is offline   Reply With Quote Quick reply to this message
Unread 08-29-2015, 07:19 AM   #2
clrussell
I have a POD brand jump pack. It's lithium ion and about the size of a phone 6 plus. It's made for diesels. I've jump started duramax trucks with dead batteries before with it.
Sent from my iPhone using Tapatalk
clrussell is offline   Reply With Quote Quick reply to this message
Unread 08-29-2015, 07:20 AM   #3
clrussell
http://www.amazon.com/FUSELED-DIESEL.../dp/B00QHJ2EHK
Unread 08-29-2015, 08:25 AM   #4
Lightninrod
2013 WK
I haven't had to use this yet but it will start diesels according to its specs.
http://www.amazon.com/ask/questions/..._ql_psf_ql_hza
Dan
Lightninrod is offline   Reply With Quote Quick reply to this message
Unread 08-29-2015, 09:47 AM   #5
jeep-rambler
Thanks, these look highly portable, but...
I was kinda hoping for one of the more standard packs that also includes an air compressor, like the other ones I have.
Anyone have experience with these with a 2014-15 GC?
Unread 08-29-2015, 09:48 AM   #6
goodburbon
1997 XJ Cherokee
The Jeep battery is 700CCA.
I have never been able to jump start it, and I've needed to several times for some weird battery drain issue that Jeep hasn't been able to figure out and somehow isn't covered by warranty, but that's another story.
I've hooked a brand new battery to the jump lugs under the hood and while it powered the jeep's electronics, there was not enough juice to do anything but make the start solenoid click. I've also hooked another vehicle to those lugs for 10 minutes with the same effect, I imagine i'd need to let that other vehicle sit connected in excess of 30 minutes to be able to jump it.
I suppose that one could disconnect the battery and hook the jump pack in it's place and 300A could work, but if I were you I'd test it before actually needing it one day.
goodburbon is offline   Reply With Quote Quick reply to this message
