Jeep WK2/JK 5x5 Wheel Encyclopedia - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Jeep WK2/JK 5x5 Wheel Encyclopedia
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 05-23-2012, 10:36 AM   #1
WKdeuce
The Jeep Cherokee Wheel Encyclopedia is a very awesome list of all the 5x4.5 wheels that came on the XJ Cherokees. I'm fairly certain this info exists for TJ/YJ wranglers as well.
This thread will be the WK2 version, but will extend to other 5x5" bolt pattern wheels that are OEM from Jeep, and if time allows, the aftermarket as well.
Try to stick to the following format:
Name/Style/Description
OEM WK2, WK, or JK, or Aftermarket
Heigth x Width (in inches) and Offset(mm) or Backspacing(inches)
Link to pic on WK2
Picture of wheel
Please correct anything that isn't right, and post up offsets and backspacking if you have the wheels. (It should be stamped somewhere in the back of the wheel ET##)
Notes:
OEM center bore is 71.5.
Please limit this thread to wheel information only, not tire info. This is not a what size tire thread, how much trimming, or what size lift to clear X thread. There's plenty of other threads for that, knowing the exact size and wheel fitment is the first step in that process. Offset is crucial.
This is for information only, please do your homework before buying anything for your Jeep, while I've tried to be as accurate as possible, I'm not liable for anything you buy or do.
If I used your picture, thanks. If you didn't want me to use it, PM me and I'll take it down.
HD brakes are bigger than standard duty. If you have HD brakes, take that into consideration when determining wheel selection.
Helpful Links:
Wheel Collision - lists all jeep wheels throughout the years
Roadkill Customs cross reference - what else might fit?
Morris 4x4 - explains bolt pattern, offset, centerbore, backspacing...
WK2 Jeeps This started as WJJeeps, and the owner(s) have been providing info for many years, thankfully it looks like they will be supporting WK2s
2011 5.7L WK2 | 5.3L TJ work in progress
Rust in Pieces Blue
JEEP FIEND CLUB
WKdeuce is offline   Reply With Quote Quick reply to this message
Unread 05-23-2012, 10:37 AM   #2
WKdeuce
WK2 Stock 16"
nope. too small.
Rust in Pieces Blue
JEEP FIEND CLUB
Unread 05-23-2012, 10:38 AM   #3
WKdeuce
WK2 Stock 17"
Raised edge 5 spoke
OEM WK2 Laredo
17x8
+56 offset / 6-1/4" backspacing
Will not clear HD brakes.
Rust in Pieces Blue
JEEP FIEND CLUB
Unread 05-23-2012, 10:39 AM   #4
WKdeuce
WK2 Stock 18"
Contoured 5 spoke
OEM WK2 Limited
18x8
measured on an 8" wheel, 56mm offset from the centerline is approximately 6-1/4" of backspacing, user posts on forums is the only data I've found on stock WK2 offset, and, allegedly applies to all 18x8" oem wheels. As I verify info, I will remove these type notes...
Raised Contoured 5 spoke
18x8
Flared Contoured 5 spoke
18x8
Mopar Black & Machined
18x8
Spare (steel wheel)
18x8
Pictures on WK2 thanks to jared57
Rust in Pieces Blue
JEEP FIEND CLUB
Unread 05-23-2012, 10:41 AM   #5
WKdeuce
WK2 Stock 20"
Contoured 5 spoke
OEM WK2 Overland
20x8
+56.4 offset - verified
measured on an 8" wheel, 56.4mm offset from the centerline is approximately 6-1/4" of backspacing.
V Spoke
OEM WK2 70th Anniversary / Durango R/T
20x8
2012 SRT8
Rust in Pieces Blue
JEEP FIEND CLUB
Unread 05-23-2012, 10:57 AM   #6
Alaska-HWY JK
Unless I missed it, don't forget that Hemi equipped GCs have the big brakes so minimum of 18" wheels are required. I'm having a hard time getting shops to gaurantee fit on 20s for my wifes Overland even after telling them it came with 18s with the Offroad 2 package. This is a post we've all been waiting for.
Alaska-HWY JK is offline   Reply With Quote Quick reply to this message
Unread 05-23-2012, 11:13 AM   #7
WKdeuce
Good point on the brakes, and worth noting.
I need your guys help to ensure this list is accurate.
Pretty sure that's all the WK2 wheels for now. I'll tackle JK next (skipping 16" due to brakes) then loop back around for WK.
Then... the endless aftermarket, which, at this point, all appear to have offset tailored for our Wrangler brethren.
Rust in Pieces Blue
JEEP FIEND CLUB
Unread 05-23-2012, 11:13 AM   #8
WKdeuce
JK Stock 17"
17" JK Rubicon
17x7.5
44.45mm offset
6" BS
thanks kkuntz01
Rust in Pieces Blue
JEEP FIEND CLUB
Unread 05-23-2012, 11:14 AM   #9
WKdeuce
JK Stock 18"
5 spoke
JK Sahara
18x7.5"
+44.45mm offset - verified
Pictures on WK2 thanks to JayB
18" jk limited
still need size info & offset/backspacing
Rust in Pieces Blue
JEEP FIEND CLUB
Unread 05-23-2012, 11:20 AM   #10
Justal13
2012 WK
You might note the difference between painted and polished/clearcoated (sometimes called "chrome", but they are actually just polished) in the descriptions, to help differentiate. Thanks.
Justal13 is offline   Reply With Quote Quick reply to this message
Unread 05-23-2012, 03:55 PM   #11
WKdeuce
Damn... This should probably expand to include XK Commander too right? They're 5x5
Rust in Pieces Blue
JEEP FIEND CLUB
Unread 05-23-2012, 03:56 PM   #12
WKdeuce
XK Stock 17"
Hulk
XK Commander
17x7.5
50.8mm / 6.25 backspacing <-- PLEASE VERIFY or do the math and you'll realize one of those numbers HAS to be wrong.
Wrench
XK Commander
17x7.5
Chrome
XK Commander
17x7.5
Rust in Pieces Blue
JEEP FIEND CLUB
Unread 05-23-2012, 03:57 PM   #13
WKdeuce
XK Stock 18"
still looking for OEM 18" Commander wheels
Rust in Pieces Blue
JEEP FIEND CLUB
Unread 05-27-2012, 09:13 PM   #14
JMP8562
Link to pic on WK2
Picture of wheel
Notes:
Helpful Links:
Thanks for taking the time to put this togather it is a great reference
89 lifted wrangler to 95 lifted cherokee to 01 GC now 07 JK 4 DOOR X WITH HIGH ROCK FRONT WINCH BUMPER APPROACH ROLLERS/WARN 9.5TI WINCH WITH UNDER THE HOOD CUT-OFF SWITCH/2.5" SS lift/1"M.O.R.E BL/33" BFG KM2 ON STOCK 17"/RIVER RAIDER ROCKER GUARDS-SLIDERS/OFF ROAD HEROS FASTBACK SOFT TOP/GIBSON DUEL EXHAUST/CUSTOM MADE TRUNK/HELLA FF300/HELLA500 W-WINDSHIELD MOUNTS/DELTA SKYBAR/CARBON FIBER DASH KIT/DUEL AND SINGLE GUAGE PODS WITH VOLT-OIL PRESSURE-OIL TEMP GUAGES/COBRA 75 CB/AND A LOT OF RECOVERY GEAR
JMP8562 is offline   Reply With Quote Quick reply to this message
Unread 05-28-2012, 09:18 AM   #15
padgett
2012 WK
For differences see codes:
BRY Anti-Lock 4-Wheel Disc Brakes (17")
BR1 Anti-Lock 4-Wheel Disc Brakes (18")
BR6 Anti-Lock 4-Wheel Disc HD Brakes
BUX other than US, Canada, or Mexico
One of these is a turbo diesel.
We take in orphans. Notary Sojac y'all.
padgett is offline   Reply With Quote Quick reply to this message
