-   WK2 Grand Cherokee Forum (http://www.jeepforum.com/forum/f309/)
-   -   Jeep WK2/JK 5x5 Wheel Encyclopedia (http://www.jeepforum.com/forum/f309/jeep-wk2-jk-5x5-wheel-encyclopedia-1372403/)
WKdeuce 05-23-2012 10:36 AM
The Jeep Cherokee Wheel Encyclopedia is a very awesome list of all the 5x4.5 wheels that came on the XJ Cherokees. I'm fairly certain this info exists for TJ/YJ wranglers as well.
This thread will be the WK2 version, but will extend to other 5x5" bolt pattern wheels that are OEM from Jeep, and if time allows, the aftermarket as well.
Try to stick to the following format:
Name/Style/Description
OEM WK2, WK, or JK, or Aftermarket
Heigth x Width (in inches) and Offset(mm) or Backspacing(inches)
Link to pic on WK2
Picture of wheel
Please correct anything that isn't right, and post up offsets and backspacking if you have the wheels. (It should be stamped somewhere in the back of the wheel ET##)
Notes:
OEM center bore is 71.5.
Please limit this thread to wheel information only, not tire info. This is not a what size tire thread, how much trimming, or what size lift to clear X thread. There's plenty of other threads for that, knowing the exact size and wheel fitment is the first step in that process. Offset is crucial.
This is for information only, please do your homework before buying anything for your Jeep, while I've tried to be as accurate as possible, I'm not liable for anything you buy or do.
If I used your picture, thanks. If you didn't want me to use it, PM me and I'll take it down.
HD brakes are bigger than standard duty. If you have HD brakes, take that into consideration when determining wheel selection.
Helpful Links:
Wheel Collision - lists all jeep wheels throughout the years
Roadkill Customs cross reference - what else might fit?
Morris 4x4 - explains bolt pattern, offset, centerbore, backspacing...
WK2 Jeeps This started as WJJeeps, and the owner(s) have been providing info for many years, thankfully it looks like they will be supporting WK2s
WKdeuce 05-23-2012 10:37 AM
WK2 Stock 16"
nope. too small.
WKdeuce 05-23-2012 10:38 AM
WK2 Stock 17"
Raised edge 5 spoke
OEM WK2 Laredo
17x8
+56 offset / 6-1/4" backspacing
Will not clear HD brakes.
http://i48.photobucket.com/albums/f2...edge5spoke.jpg
WKdeuce 05-23-2012 10:39 AM
WK2 Stock 18"
Contoured 5 spoke
OEM WK2 Limited
18x8
measured on an 8" wheel, 56mm offset from the centerline is approximately 6-1/4" of backspacing, user posts on forums is the only data I've found on stock WK2 offset, and, allegedly applies to all 18x8" oem wheels. As I verify info, I will remove these type notes...
http://i48.photobucket.com/albums/f2...ured5spoke.jpg
Raised Contoured 5 spoke
18x8
http://i48.photobucket.com/albums/f2...tour5spoke.jpg
Flared Contoured 5 spoke
18x8
http://i48.photobucket.com/albums/f2...ared5spoke.jpg
Mopar Black & Machined
18x8
http://i48.photobucket.com/albums/f2...ckmachined.jpg
Spare (steel wheel)
18x8
Pictures on WK2 thanks to jared57
http://i48.photobucket.com/albums/f2...steelwheel.jpg
WKdeuce 05-23-2012 10:41 AM
WK2 Stock 20"
Contoured 5 spoke
OEM WK2 Overland
20x8
+56.4 offset - verified
measured on an 8" wheel, 56.4mm offset from the centerline is approximately 6-1/4" of backspacing.
http://i48.photobucket.com/albums/f2...keoverland.jpg
V Spoke
OEM WK2 70th Anniversary / Durango R/T
20x8
http://i48.photobucket.com/albums/f2...niversaryV.jpg
2012 SRT8
http://cdn.jeepforum.com/forum/attac...rt8-wheels.jpg
Alaska-HWY JK 05-23-2012 10:57 AM
Unless I missed it, don't forget that Hemi equipped GCs have the big brakes so minimum of 18" wheels are required. I'm having a hard time getting shops to gaurantee fit on 20s for my wifes Overland even after telling them it came with 18s with the Offroad 2 package. This is a post we've all been waiting for.
WKdeuce 05-23-2012 11:13 AM
Good point on the brakes, and worth noting.
I need your guys help to ensure this list is accurate.
:rtft:
Pretty sure that's all the WK2 wheels for now. I'll tackle JK next (skipping 16" due to brakes) then loop back around for WK.
Then... the endless aftermarket, which, at this point, all appear to have offset tailored for our Wrangler brethren.
JK Stock 17"
17" JK Rubicon
17x7.5
44.45mm offset
6" BS
thanks kkuntz01
http://i48.photobucket.com/albums/f2...x75rubicon.jpg
WKdeuce 05-23-2012 11:14 AM
JK Stock 18"
5 spoke
JK Sahara
18x7.5"
+44.45mm offset - verified
Pictures on WK2 thanks to JayB
http://i48.photobucket.com/albums/f2...8x75sahara.jpg
18" jk limited
still need size info & offset/backspacing
http://i48.photobucket.com/albums/f2...x75limited.jpg
Justal13 05-23-2012 11:20 AM
You might note the difference between painted and polished/clearcoated (sometimes called "chrome", but they are actually just polished) in the descriptions, to help differentiate. Thanks.
WKdeuce 05-23-2012 03:55 PM
Damn... This should probably expand to include XK Commander too right? They're 5x5
WKdeuce 05-23-2012 03:56 PM
XK Stock 17"
Hulk
XK Commander
17x7.5
50.8mm / 6.25 backspacing <-- PLEASE VERIFY or do the math and you'll realize one of those numbers HAS to be wrong.
http://i48.photobucket.com/albums/f2...k17x75hulk.jpg
Wrench
XK Commander
17x7.5
http://i48.photobucket.com/albums/f2...7x75wrench.jpg
Chrome
XK Commander
17x7.5
http://i48.photobucket.com/albums/f2...7x75chrome.jpg
WKdeuce 05-23-2012 03:57 PM
XK Stock 18"
still looking for OEM 18" Commander wheels
JMP8562 05-27-2012 09:13 PM
Link to pic on WK2
Picture of wheel
Notes:
Helpful Links:
:thumbsup: Thanks for taking the time to put this togather it is a great reference :cheers2:
padgett 05-28-2012 09:18 AM
For differences see codes:
BRY Anti-Lock 4-Wheel Disc Brakes (17")
BR1 Anti-Lock 4-Wheel Disc Brakes (18")
BR6 Anti-Lock 4-Wheel Disc HD Brakes
BUX other than US, Canada, or Mexico
http://padgett.performanceresearch.us/anima7.gif
One of these is a turbo diesel.
The time now is 10:59 PM.
Powered by vBulletin Version 3.8.4
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
