Its time - JeepForum.com
post #1 of 9 Old 06-05-2013, 08:15 PM Thread Starter
t-ray-foret
2011 WK
Its time
Well my wife's grand Cherokee limited has about 40,000 miles on it now. When I get in from offshore in plan on taking a little time and doing some matinance on it, it has dual 40 series flow masters a h pipe and a k&n intake and a jet throttle body spacer on it. I might drive it once a week but when I do I am hard on it.
I plan on changing the oil, cleaning the intake, changing the trans fluid and filter, spark plugs, and doing the ccv mod with a catch can I need to read up on that, any other things y'all can think of that are good to do at this point, also does anyone make headers for the gc with a hemi yet?
Last edited by Jackal01; 06-05-2013 at 08:43 PM. Reason: Not sure why you quoted yourself. FIFY
t-ray-foret is offline
post #2 of 9 Old 06-06-2013, 02:04 AM
Dave2002ti
2012 WK
Cleaning Intake
Before you clean the intake read Jeep's maintenance recommendations. Jeep does not recommend cleaning the throttle body.
Dave2002ti is offline
post #3 of 9 Old 06-06-2013, 02:59 AM
pwrdbym
If you're going to change the tranny fluid, then why not the diff(s) fluid as well?
pwrdbym is offline
post #4 of 9 Old 06-06-2013, 03:35 AM
loveracing1988
Don't install a throttle body spacer, they are a total waste of money, most of them actually hurt performance.
loveracing1988 is offline
post #5 of 9 Old 06-07-2013, 12:45 PM Thread Starter
t-ray-foret
2011 WK
To late on the spacer it's been on for like 15,000 miles. I didn't mean the intake I meant the air filter. Yes good call on the diff fluid as well
post #6 of 9 Old 06-07-2013, 03:38 PM
xjrguy
If it's 4wd do the transfer case fluid too.
Wouldn't hurt to siphon out the power steering fluid and replace with fresh too.
Belts?
Cabin air filter?
xjrguy is offline
post #7 of 9 Old 06-11-2013, 03:44 PM
txwest
2012 WK
Originally Posted by xjrguy View Post
Cabin air filter?
Never a bad idea
Sent from my S-III using JeepForum
Current:
'12 GC Overland 4x4 HEMI ORII QL Towing Red/Saddle
Past Jeeps:
'80 CJ-7 I6 4x4 Std
'86 Comanchee I4 4x4 Std
'99 WJ Laredo 4.0 4x4 AWD
txwest is offline
post #8 of 9 Old 12-11-2013, 08:19 PM
jeepsterguy
2011 WK
Belts?
Cabin air filter?
What fluid would you use?
My 2011 came with ATF+4, later manuals show CHF11s and another couple but no ATF+4. They don't even show ATF+4 as an alternative.
I doubt the two types are mixable.
What's the deal?
jeepsterguy is offline
post #9 of 9 Old 12-13-2013, 02:33 PM
Dabitz
2015 WK
Drive belts is 120k miles. I looked into it since I'm at 56k. I changed differential and xfercase fluids to Redline.
Dabitz is offline
