Installed aftermarket radio, weird EVIC issue - JeepForum.com
post #1 of 8 Old 03-05-2012, 03:48 PM Thread Starter
RageOfFury
2014 WK
I installed an aftermarket double-din radio this past weekend. I pretty much did what JGC11 did in his thread (http://www.jeepforum.com/forum/f309/...dunit-1320196/) using the same wiring harnesses/interfaces.
The installation went well and the radio is working beautifully. The only issue I am having is that the EVIC is switching to Spanish when I unlock the doors in the morning/after work. I have to switch the EVIC back to English each time.
I was wondering if JGC11 had the same issue (I tried to PM you but your mailbox is full). I am thinking that I perhaps have a faulty PAC-Audio C2R-CHY4 Jeep replacement interface. Though everything else is working perfectly.
RageOfFury is offline
post #2 of 8 Old 03-05-2012, 04:14 PM
nightsordays
2011 WK
Did you check if you got the latest version of the PAC adapter because those adapters got a couple times updated to eliminate errors like yours. You may check with their costumer service.
http://www.pac-audio.com/support.aspx
nightsordays is offline
post #3 of 8 Old 03-05-2012, 04:19 PM Thread Starter
RageOfFury
2014 WK
I did indeed check that. I have version 1.1.4a. The newest version (1.1.6) corrects only 1 (published) issue which is Fixes "No Signal" text on instrument cluster seen in 2012 vehicles. There is no version 1.1.5
Perhaps 1.1.6 also fixes the EVIC spanish issue I'm having. I'm hoping JGC11 will chime in.
post #4 of 8 Old 03-05-2012, 07:39 PM
JGC11
2011 WK
Hmmm I haven't had any issue with this whatsoever... and sorry about the PM's I will clear the inbox asap.
Maybe if you reset the PAC adapter/re program it? This is really all I can think about trying to fix this... Maybe give PAC a call or crutchfield.
JGC11 is offline
post #5 of 8 Old 03-05-2012, 07:46 PM Thread Starter
RageOfFury
2014 WK
Did you disconnect the battery when you swapped out the radio? I totally forgot to do that and only realized this once I had the new unit installed. I'm going to disconnect the battery, thus "resetting" the Jeep to see if that fixes it. If not, then I will double check the wiring and I may give PAC or Crutchfield a call.
Another question for ya. The stock radio had 2 wiring harnesses plugged into it. One harness with a lot of wires, the other had only 3. I hooked up the PAC interface to the first harness, leaving the harness with 3 wires disconnected. Is that what you did?
post #6 of 8 Old 03-05-2012, 08:48 PM
JGC11
2011 WK
I did dis connect the battery...
Yes I left the 2nd one unplugged like you did. I think that that one is for factory NAV and because they mass produce these things its there on all models
JGC11 is offline
post #7 of 8 Old 03-05-2012, 08:58 PM Thread Starter
RageOfFury
2014 WK
Right on. Well I'll disconnect the battery this weekend to "reset" the Jeep to see if that will fix things. I'll also double check the wiring.
Cheers
post #8 of 8 Old 03-11-2012, 09:11 AM Thread Starter
RageOfFury
2014 WK
I disconnected the battery for about an hour. Issue resolved!
Caution if installing aftermarket radio sost1sg WK2 Grand Cherokee Forum 41 07-21-2012 08:18 AM
Help with an EVIC problem TyWebb1973 WK2 Grand Cherokee Forum 13 06-11-2012 07:52 AM
Radio Issue - Touch Screen Blank jjallen WK2 Grand Cherokee Forum 8 01-30-2012 02:56 PM
430n radio acted weird today Smokestogi WK2 Grand Cherokee Forum 1 12-30-2011 10:47 AM
evic instance mpg WvTaco WK2 Grand Cherokee Forum 3 12-28-2011 11:52 AM
