HVAC whirling noise - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > HVAC whirling noise
FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectRIGID LED Light Blowout Sale - All Sizes, All Series, all Toxic Brakes - 3000 PSI Braided Stainless Steel Brake Line
Unread 01-25-2015, 09:32 AM   #1
Bezy9530
HVAC whirling noise
Hi All-
I'm experiencing what I can only describe as a "whirling" noise coming from the passenger side heating/AC vent when the heat is on. The problem started immediately when a pile of snow crashed down the windshield from my roof. I checked the cabin filter, and there is no debris in it that would make that noise, but when I pulled it out, it was very damp. The sound seems to be coming from that area though. Could something be lodged in the fan or something? Thanks in advance. I feel like I may have to have the dealer look into this, but if it could be a quick fix, I would definitely prefer that!
Bezy9530 is offline   Reply With Quote Quick reply to this message
Unread 01-25-2015, 10:45 AM   #2
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
The blower motor/fan is pretty easy to drop down out of the housing if you wanted to bother to check it.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote Quick reply to this message
Unread 02-19-2015, 09:03 AM   #3
Jughead
2011 WK
Wife's just started making noise, took it in.....blower motor replacement. $100 deductible with care max
2003 Rubicon
2011 Laredo "X" V-6
2011 Laredo Limited Hemi
1970 Corvette Stingray 454
Jughead is offline   Reply With Quote Quick reply to this message
Unread 02-19-2015, 02:05 PM   #4
14summithemi
2014 WK
Mine had a high pitched squeal that was a bad blower motor bearing but it only appeared on setting if 7...6 and below was silent. Happened to factory motor and the replacement....3rd motor silent on 7
14summithemi is offline   Reply With Quote Quick reply to this message
Unread 02-19-2015, 05:53 PM   #5
diverb
2014 WK
Mine does it also, noticed it the other day while I was trying to take a nap in a rest area while letting her idle and the heat on. Annoying but I can live with it
2014 Jeep Grand Cherokee 3.0 diesel -BANKS Tuner, BANKS Exhaust, BANKS Single shot water-meth injection
diverb is offline   Reply With Quote Quick reply to this message
Unread 02-19-2015, 06:44 PM   #6
Pardo714
2011 WK
Mine was the same, got worse the colder it got. Like Jughead I took it in and the blower motor was replaced with the 100 deductible, problem solved.
2011 Jeep Grand Cherokee Overland, 5.7L Hemi, Black 4x4
Pardo714 is offline   Reply With Quote Quick reply to this message
