HVAC Fan cycles to low speed every minute or two - JeepForum.com
post #1 of 5 Old 06-19-2014, 12:25 PM Thread Starter
RMFLMFRLF
2013 WK
2013 JGC Limited - 40k miles - 3.6l Pentastar
The interior climate control fan cycles to low speed setting every minute or so, stays there for a few minutes, then goes back to the correct setting. The fan indicator bar graph does not change. Adjusting the controls has no effect - not even turning the HVAC on and off. Putting it in gear, and speeding up/slowing down has no effect.
UPDATE
After more investigation - the passenger side is blowing warm air at higher fan speeds - even though the temp is set to LO
This seems to be similar to some of the other posts about HVAC control problems that ended up having a TSB for updated software
I talked to the service manager at the dealer where I purchased and they say they have not heard of any similar problems. This just started last week and I have only used AC, not sure if it happens on vent or heat settings.
RMFLMFRLF is offline
post #2 of 5 Old 06-20-2014, 02:13 PM
MarkSRT8
2012 WK
I have noticed on my 2012 that the HVAC fan speed increases/decreases when the cooling fan cycles on/off.
MarkSRT8 is offline
post #3 of 5 Old 07-09-2014, 08:00 AM Thread Starter
RMFLMFRLF
2013 WK
UPDATE
I ended up having the dealer look at the problem while there for the brake booster recall. It turns out the problem was the blend door issue that is talked about in other threads. It sounded like the fan speed would change when apparently it was the blend door opening and closing to block the air flow. The dealer charged $2 for the part and two hours labor at $75/hr for a total of $161 with tax. I consider that reasonable. However, I am not happy with JEEP as this is a very common problem (for many years) that should be considered a manufacturer defect and fixed for free. My 2013 is 5,000 miles out of warranty already.
post #4 of 5 Old 07-09-2014, 03:01 PM
bluegrassguitar
2011 WK
I thought I had the blend door issue, too, with my 2011 Laredo. Only slightly cool air (80 deg) coming from the driver's vents, very warm air (90+ deg) on the passenger side, checked with a vent thermometer. Turned out to be a clogged filter and "slightly" low refrigerant level. After being fixed yesterday, it will freeze ice cream.
bluegrassguitar is offline
post #5 of 5 Old 07-09-2014, 03:05 PM
bluegrassguitar
2011 WK
Oh, yeah...my fan does speed up and slow down if the a/c is set to auto. I suppose that's normal to maintain the set temperature.
