How do you get map to look like this? (Pic) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > How do you get map to look like this? (Pic)
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineORS Recovery RopeSynthetic Winch Rope from ORS
Unread 02-17-2015, 10:18 PM   #1
02jeepliberty
Was watching a YouTube video and noticed the map was 3D, how do you get it in this mode?
02jeepliberty is offline   Reply With Quote Quick reply to this message
Unread 02-17-2015, 10:25 PM   #2
perpster
2015 WK
In Options, Settings, you'll find the Map choices. Each press cycles through them.
Options "button" is on the lower right of map screen, to the right of "10th Ave".
perpster is offline   Reply With Quote Quick reply to this message
Unread 02-17-2015, 11:01 PM   #3
02jeepliberty
Originally Posted by perpster
In Options, Settings, you'll find the Map choices. Each press cycles through them. Options "button" is on the lower right of map screen, to the right of "10th Ave".
I'm not seeing the map choices tab. All I see is this
Unread 02-18-2015, 12:18 AM   #4
perpster
2015 WK
Scroll down a bit further on the Settings - Map Setup (your last picture). You will see some check boxes, including 3D cities, 3D landmarks. Check all those boxes.
Unread 02-18-2015, 08:00 AM   #5
02jeepliberty
Ok, thank you, it worked!
Unread 02-18-2015, 08:49 AM   #6
lurtonk
Drive it like u stole it
2015 WK
I tried but this doesn't work on my '15 JGC Overland.
Asked my daughter (she is a product specialist with FCA) and she asked the Jeep specialist and he said the 3D was only available in certain large cities.
Nashville must not be one.
lurtonk is offline   Reply With Quote Quick reply to this message
Unread 02-18-2015, 08:51 AM   #7
jim_in_PA
2012 WK
Also requires the RA4 (8.4AN)
2012 Grand Cherokee Overland Summit 5.7L V8 - Winter Chill with New Saddle Interior - Nitto NT421Q
jim_in_PA is offline   Reply With Quote Quick reply to this message
Unread 02-18-2015, 09:31 AM   #8
BlckWK2
2014 WK
As mentioned above, the RA4 (8.4AN) is required to utilize 3D maps. Can I assume the Overland's come standard equipped with the RA4?
Also, can she ask the Jeep specialist when the map updates will be available for the RA4 (8.4AN) Jeep models with Navigation. Everyone is sitting on late 2012 year maps!
BlckWK2 is offline   Reply With Quote Quick reply to this message
Unread 02-18-2015, 10:09 AM   #9
lurtonk
2015 WK
I asked the same thing and he said something about the updates are sourced from Garmin not FCA.
My Overland came with the 5-year Traffic which is only on 8.1AN
Unread 02-18-2015, 01:36 PM   #10
BiLLyb0b
2014 WK
man.... I don't think the 3D images work for Houston!
BiLLyb0b is offline   Reply With Quote Quick reply to this message
Unread 02-18-2015, 01:42 PM   #11
ssgunner
I need to try this for cali.
ssgunner is offline   Reply With Quote Quick reply to this message
Unread 02-18-2015, 02:12 PM   #12
lurtonk
2015 WK
Where was the you-tube poster located?
There was no location only 56th street.
Unread 02-18-2015, 03:26 PM   #13
perpster
2015 WK
That is the west side of Manhattan, roughly between the Lincoln Tunnel to NJ on the left (west), and the Port Authority Bus Terminal to the right (east).
Unread 02-18-2015, 06:10 PM   #14
silverfox9142
That's interesting. Garmin updates the maps on my Nuvi 4 times a year. How often are the maps on the Jeep updated?
silverfox9142 is offline   Reply With Quote Quick reply to this message
Unread 02-24-2015, 09:07 PM   #15
FreakyK
2014 WK
Chrysler does not use Garmin. They use a company called HERE which is either NAVTEQ or a part of them.
I would have like it if they used Garmin that we could actually get some updates.
FreakyK is offline   Reply With Quote Quick reply to this message
