How do I remove rear wiper arm on 2012 GC Overland - JeepForum.com
post #1 of 4 Old 01-13-2014, 12:31 PM Thread Starter
johnnya
2012 WK
The rear wiper has for some reason, decided that "home base" is below horizontal, so that part of its excursion is over the finish below the rear window. I explored removing and resetting the wiper arm, but I can't figure out how to remove the arm from the shaft.
Can somebody give me instructions?
Thanks
johnnya is offline
post #2 of 4 Old 01-13-2014, 02:18 PM
97HMCS
2012 WK
Rear Wiper Blade Removal/Installation
1. Lift the pivot cap on the rear wiper arm upward, this
will allow the rear wiper blade to be raised off of the
liftgate glass.
NOTE: The rear wiper arm cannot be raised fully
upward unless the pivot cap is raised first.
2. Lift the rear wiper arm upward to raise the wiper
blade off of the liftgate glass.
3. Grab the bottom of the wiper blade and rotate it
forward to unsnap the blade pivot pin from the wiper
blade holder.
4. Install the wiper blade pivot pin into the wiper blade
holder at the end of the wiper arm, and firmly press the
wiper blade until it snaps into place.
5. Lower the wiper blade and snap the pivot cap into
place.
97HMCS is offline
post #3 of 4 Old 01-13-2014, 03:43 PM
2kg4u
2014 WK
liftgate glass.
blade holder.
place.
Those are instructions for changing the wiper blade, not the arm. Remove the plastic cap at the base of the arm (near the pivot point) and see how the arm is attached. There is probably a nut, and press fit on to a spline. Remove the nut, and you may need a small wheel puller to get the arm off the spline. If you don't have a wheel puller, you can try prying gently to see if you can get it off.
I have not looked at mine to tell you for sure there is a nut holding it on, but the first step is to remove that plastic cover and see what is there.
Roy
2014 Overland, 3.6 L
Fumoto Qwikvalve, Ionic CXV running boards, Michelin X-Ice Xi2 snow tires
2kg4u is offline
post #4 of 4 Old 01-13-2014, 04:02 PM Thread Starter
johnnya
2012 WK
Thanks!
The plastic cap over the shaft snaps open away from the blade. Under it is a metric nut which comes off pretty easily. I was surprised to find that the grooves of the spline were very shallow. It was easy to reset the arm to a new home base, but I'm afraid with any resistance, it will move on the spline.
For now, we're happy!
johnnya is offline
