Horn randomly stops working - JeepForum.com
post #1 of 8 Old 03-27-2011, 01:42 PM Thread Starter
one11sgt
I am having a problem with my horn. It randomly stops working for about 30 seconds then will start again.
My service manager said it is a built in safety to protect the horn. I can understand this if I was pressing on the horn for minutes at a time. But Sometimes the horn will stop working after even a 2 or 3 second blow.
Driving in a metropolitan area, I have had 3 instances now, where I needed the horn at multiple times in close proximity to each other and it has failed to work. This is very dangerous.
I think there is something more to my problem since the "horn protection" seems random. While testing it to recreate the issue, sometimes it stops working in seconds, sometimes I can hold it in for over a minute before it stops.
Protection I can understand, if the protection kicked it at the same time every time, mine does not, and I never know if the horn is going to work when I need it.
Any one else experience this?
one11sgt is offline
post #2 of 8 Old 03-27-2011, 04:51 PM
silver04
2011 WK
How did I know you were in new york without even looking.
silver04 is offline
post #3 of 8 Old 03-28-2011, 11:07 PM
DennisU
2011 WK
If I had to guess, I would say you need to check for a loose ground wire in the horn circuit.
DennisU is offline
post #4 of 8 Old 03-28-2011, 11:42 PM
volvite
you shouldn't have to look for a loose ground, but go to another dealership and let them know your problem. They should fix it.
His 99 WJ Limited 4.7
Hers 15 Overland EcoDiesel, ORAII
volvite is offline
post #5 of 8 Old 03-29-2011, 07:42 AM
JeepOrvis97
JeepOrvis97's Avatar
"horn protection" I'm pretty sure sounds like a made up answer.
Current jeeps:
1997 ZJ Orvis
1997 TJ 4.0L 5-speed
1993 YJ Sahara Trail Rig
JeepOrvis97 is offline
post #6 of 8 Old 03-29-2011, 09:49 PM
LuckRider
LuckRider's Avatar
Time for a new dealership. If it were a safety function, it would do it the same way all the time.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #7 of 8 Old 03-30-2011, 08:41 PM Thread Starter
one11sgt
Thank you all. The dealership said thats what chrysler told them. I will push the issue and see what happens.
one11sgt is offline
post #8 of 8 Old 03-30-2011, 09:09 PM
JeepOrvis97
dealers definitely make things up quite often and usually its to cover up a lack of knowledge, sometimes it's not as bad when you talk directly to the tech.
Current jeeps:
1997 ZJ Orvis
Deals Are A Working fleuger99 WK2 Grand Cherokee Forum 15 02-19-2011 04:12 AM
Passive Entry Module not working - now fixed RRER WK2 Grand Cherokee Forum 3 10-27-2010 10:02 AM
