Hole in exhaust [Pic] - JeepForum.com
post #1 of 4 Old 06-25-2014, 03:35 PM Thread Starter
Chael
So I have V8 Hemi. There is a perfect round small hole on both exhaust in the same spot that leaks what looks like water. Is this normal? The car smells like gas vapor inside. Trying to find out if there is a leak somewhere.
Chael is offline
post #2 of 4 Old 06-25-2014, 03:51 PM
10Xk
2014 WK
Its meant to be there check exhaust manifolds
10Xk is offline
post #3 of 4 Old 06-25-2014, 08:56 PM
NYFDWK2
2014 WK
The hole in the exhaust is for the condensation to drain out. As for the gas smell, it could be as simple as someone stepping in gasoline and getting into your car. Did this happen after you went to fill up?
NYFDWK2 is offline
post #4 of 4 Old 06-26-2014, 06:33 AM
GaryGC
Combustion gas (exhaust) contains water. Some cars have drain holes in the lowest section of exhaust while others just send it out the tailpipe. This is normal.
GaryGC is offline
