Hitch Ball Mount - JeepForum.com
post #1 of 7 Old 03-06-2012, 09:05 AM Thread Starter
tophs
2012 WK
Hitch Ball Mount
Never had a vehicle with a hitch before. Wondering what is best drop spec for my new Laredo X? 2" drop? What are you all using? Thnx
tophs is offline
post #2 of 7 Old 03-06-2012, 10:41 AM
txwest
2012 WK
2" is the standard for normal trailer ride height on most SUVs. Anything else requires a special hitch plug: big lift, heavy trailer, really long trailer, etc etc.
And for most small trailers with a heavy load, you can flip the 2" hitch and ball over to allow for the vehicle sag from the heavy load.
Current:
'12 GC Overland 4x4 HEMI ORII QL Towing Red/Saddle
Past Jeeps:
'80 CJ-7 I6 4x4 Std
'86 Comanchee I4 4x4 Std
'99 WJ Laredo 4.0 4x4 AWD
txwest is offline
post #3 of 7 Old 03-06-2012, 12:33 PM
SPL170db
I have to use a 10'' drop with my enclosed trailer that I just got
With my old 5x8 utility trailer it needed a 6'' drop to sit level
and prior to that 1 had a 3-rail motorcycle trailer that used a 2'' drop
So really it all depends on the kind of trailer that you are using.
SPL170db is offline
post #4 of 7 Old 03-06-2012, 12:49 PM Thread Starter
tophs
2012 WK
It will be used with a run-of-the-mill Home Depot utility trailer. So I guess it sounds like 6". Thanks
tophs is offline
post #5 of 7 Old 03-06-2012, 04:36 PM
Justal13
2012 WK
Just bought a 6 1/4" drop with a 1 7/8" ball for my utility trailer and a 3 1/2" drop with a 2" ball for my larger enclosed trailer.
The GC is 18.5" from the center of the receiver to the ground. I want my trailers to be level when hitched.
I also bought a hitch case for each. It fits nicely in the bins next to the spare tire.
http://www.amazon.com/Classic-Accessories-74877-Hitch-Tote/dp/B000XLXWQ0/ref=sr_1_1?ie=UTF8&qid=1331076839&sr=8-1
Justal13 is offline
post #6 of 7 Old 03-06-2012, 06:45 PM
padgett
2012 WK
With a two wheel trailer, I do not believe it really matters as long as close. With a 4 wheel trailer you want to keep the load even and not lift one axle off the ground. Since I have a single axle teardrop and a two wheel dolly, 3.5" drop seems OK.
One of these is a diesel.
We take in orphans. Notary Sojac y'all.
padgett is offline
post #7 of 7 Old 03-06-2012, 08:24 PM
WvTaco
2011 WK
enough to make the trailer level.
WvTaco is offline
Does anyone have experience with enclosed hitch mount cargo carriers? WKDiesel56 WK2 Grand Cherokee Forum 4 03-01-2012 06:36 PM
Aftermarket Tow Hitch? camaro307 WK2 Grand Cherokee Forum 4 01-17-2012 07:54 AM
Trailer hitch question LMust145 WK2 Grand Cherokee Forum 15 11-30-2011 09:55 PM
Aftermarket hitch question Moparluvr WK2 Grand Cherokee Forum 8 05-08-2011 02:06 PM
Hitch and tow hook install - anyone? REALM WK2 Grand Cherokee Forum 2 03-21-2011 12:41 PM
