Hemifever tune with Diabsport Tuners - Page 2 - JeepForum.com
 1Likes
post #16 of 67 Old 03-25-2013, 03:19 PM
shudog
2012 WK
so when you call Hemifever for a tune, what sort of options are actually available? Does he ask about shift firmness settings? Obviously there are options on the 89/93 octane tunes...
Previously owned jeeps:
'06 Grand Cherokee Limited w/4.7L V8 & QD2
'98 Grand Cherokee Limited w/5.2L V8 & Quadra Trac - sold at 230k miles
shudog is offline
post #17 of 67 Old 03-25-2013, 05:40 PM
doz
2012 WK
What options are you looking for specifically? There are options yes. You can give him an idea of what you are looking for. I wanted quicker downshifts and thus he gave it to me
doz is offline
post #18 of 67 Old 03-26-2013, 06:44 AM Thread Starter
dizz1979
2012 WK
The only thing I told Sean was that I had a Mopar CAI and I wanted to make sure I got the most out of the increased airflow with his tune. THat is the only thing I asked for. I got more power and quick decisive shifts and downshifts. That comes without asking.
dizz1979 is offline
post #19 of 67 Old 03-26-2013, 10:39 PM
007-MEDIC
Well I started out my evening trying to install the Diablo 91 tune so I could come inside and get the hemifever tune. But after installing the tune with my 265/65/18 tire size I now have an ABS light I can't get rid of. I restored to the factory settings but it's still there. Not pleased. Emailed everyone I could find and I am tired of trolling the forums.
Anyone else have this issue?
007-MEDIC is offline
post #20 of 67 Old 03-26-2013, 11:01 PM
DirtyDuc83
That seems like a common issue when changing the tire size...I don't believe there has been a fix determined. Maybe driving around awhile with the stock tune back on will eventually turn the ABS Light off, or see if you can clear it with the DTC scan tool in the intune...
DirtyDuc83 is offline
post #21 of 67 Old 03-27-2013, 02:11 AM
doz
2012 WK
Yeah, the tire size change is an issue that is well known and documented extensively on their forums as well as others (RAM forums especially). No fix as of yet. You have to remember that tuning just became available and there will be minor issues. They will be worked out.
Restore the stock tune, clear the code and you should be good to go. If that doesnt work, then pull the battery cable and have the PCM reset.
doz is offline
post #22 of 67 Old 04-02-2013, 03:45 AM Thread Starter
dizz1979
2012 WK
Did that solve your problem with the light?
dizz1979 is offline
post #23 of 67 Old 04-02-2013, 08:05 AM
007-MEDIC
I talked to the guys at Diablo last week. They said a fix should be out very soon to correct the ABS light issue. It might be out I haven't checked for updates yet this week.
I left mine on, the tune is so much better I can live with the light for a bit. Sean at Hemifever also mentioned they are correcting an issue with the 2011s not uploading custom tunes.
post #24 of 67 Old 04-03-2013, 07:55 AM
lysol
2013 WK
They need to get on the '13... Still nothing yet.
MINE > '14 JKUR Anvil
HERS > '13 WK2 Overland Summit V8 Mineral Grey
lysol is offline
post #25 of 67 Old 04-03-2013, 08:55 AM
txwest
2012 WK
The rest of us had to wait Several Years to finally get a tune......
Sent from my S-III using JeepForum
Current:
'12 GC Overland 4x4 HEMI ORII QL Towing Red/Saddle
Past Jeeps:
'80 CJ-7 I6 4x4 Std
'86 Comanchee I4 4x4 Std
'99 WJ Laredo 4.0 4x4 AWD
txwest is offline
post #26 of 67 Old 04-03-2013, 08:37 PM
13ovsummit
2013 WK
Wk
+1 - not liking the years of waiting comment(s) I read above - but, it is what it is I guess. Sean @ hemifever seems to be further along than the other vendors/tuners - I'll be keeping a close eye on his efforts for sure.
Rob
13ovsummit is offline
post #27 of 67 Old 04-03-2013, 11:15 PM
007-MEDIC
Talked to them again today. The ABS fix was supposed to be out today' but again I haven't seen it. The tune is great but not impressed with their communication.
post #28 of 67 Old 04-03-2013, 11:39 PM
DirtyDuc83
Thanks for the update. Please post up when you find out the fix. Been holding off on the tire size change until this issue is resolved.
post #29 of 67 Old 04-04-2013, 02:23 PM
Raptor
Already mounted larger P275/55R20 tires.
Can't wait to try one of these tunes, but if I can't change the tire size to correct speedometer and odometer readings I'll wait until Diablo gets the ABS light issue straightened out.
Raptor is offline
post #30 of 67 Old 04-04-2013, 08:28 PM
DirtyDuc83
Oh I already have larger tires...i just havent changed it in the tuner yet because I dont want the ABS light on.
