Help on finding wheels for lifted WK2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Help on finding wheels for lifted WK2
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiFree shipping on slip yoke eliminator kits New lower PriceNew! JK/U skid plate system.
Unread 09-01-2012, 11:43 AM   #1
JasonJasoff
2012 WK
Wk Help on finding wheels for lifted WK2
First off, going to any website and putting in 2012, grand cherokee laredo x, results in about 5 wheels. I want to get a new set for my jeep thats now lifted with the 2.5" RRO lift kit. Can someone please help me in my search? What are the specs on our wheels? I know they are 18" 5x5 but I have no idea on backspacing and offset. Also, what sizes wheels will fit on this jeep? What are the ranges of offset and backspacing we can use? Anything and everything will help. Thanks!
JasonJasoff is offline   Reply With Quote Quick reply to this message
Unread 09-01-2012, 01:27 PM   #2
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
There are two wheel/tire sticky threads above which are a collection of information for wheels and tires, what fits, what doesn't. Wheels/tire selection can be subjective, its probably best that you browse through those threads and come back with more specific questions.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote Quick reply to this message
Unread 09-01-2012, 01:49 PM   #3
JasonJasoff
2012 WK
Ya, I've viewed them both already. No help. Specific questions? You mean to tell me, "What are the specs on our wheels?" and "What are the ranges of offset and backspacing we can use?" are not specific enough? LOL. Anyway, can anyone confirm if these wheels fit:
Specs:
ATX188 Ledge
Wheel Size: 18x9
5 on 5 Bolt Pattern
Offset: 0
Backspace: 5
http://www.4wheelparts.com/Wheels/AX...PAX18889050600
Hope thats specific enough :|
Unread 09-01-2012, 02:49 PM   #4
ColdCase
ColdCase's Avatar
2011 WK
Whoops, I guess its this sticky thread with wheel details.
If you look at the inside of your wheels, they are stamped with size and offset. My 18s are stamped with 56.4.
http://www.jeepforum.com/forum/f309/...pedia-1372403/
If your wheel info isn't in those threads, then you are going to be an early adopter here. Let us know what you find out.
This site seems to have a bit more info: http://www.rimsntires.com/packages.j...earch&sized=18
(775x265mm). Bolt pattern: 5x127 (5x5). Offset: 18 to 45 mm. Tires up to 800x275mm. Rims up to 26x9.5".
That site lets you select stock or lifted, dunno how much you can trust it.
You can play with rim and tire sizes here:
http://www.rimsntires.com/specs.jsp?item=Wheel-Tire
They say the OEM 18 inch wheel has a 173 mm BackSpace, 45 mm offset, 9 inch width, however.
Depending on your lift, you may have fender clearance issues with that 0 offset, it will stick out near 2 inches more than the OEMs.
Unread 09-01-2012, 09:15 PM   #5
Jackal01
Jackal01's Avatar
2011 JK Wrangler
The stickies helped me. There are multiple lifted WK2s here, including mine. We all managed to figure it out.
2011 Billet JKUS
Jackal01 is offline   Reply With Quote Quick reply to this message
Unread 09-02-2012, 10:49 PM   #6
JasonJasoff
2012 WK
Thanks for the info, helped A LOT! I also found that the guys at 4wheelparts.com are really helpful and you can just email the wheel guy there and he can check fitment!
Unread 09-03-2012, 02:18 PM   #7
MaineJeep11
2011 WK
Keep in mind 4wheel parts can give general fitment data but they won't give you a lot of detail regarding offset and backspacing relative to your specific vehicle . A number of us with after market wheels with zero to negative offset and relative to stock have had to deal with vibrations and shimmies at higher speeds. These wk2's are very sensitive to Aftermarket wheels and tires so choose carefully.
2011 Laredo V6, OR1, RR 2.5" lift, ProComp 7036 wheels, 265/70/17 Toyo Open Country AT's - SOLD
MaineJeep11 is offline   Reply With Quote Quick reply to this message
Unread 09-03-2012, 04:12 PM   #8
Jackal01
Jackal01's Avatar
2011 JK Wrangler
+1 on the vibration. Mine was very minute and may have been eliminated now after time. Or I just don't notice it.
2011 Billet JKUS
Unread 09-03-2012, 07:55 PM   #9
JasonJasoff
2012 WK
Thanks for the heads up guys
Unread 09-05-2012, 07:16 AM   #10
CaniacNation
Stay away from my setup...it was a real pain to get it to a tolerable level of vibrations. I hope by the time I have to get my next set of tires, there is a more definitive choice for smoothness figured out by the forum. Whatever setup you go with, make sure the installers have a Road Force balancing machine since that appears to be the best thing out there. I'm also dealing with rubbing up front, which I'm just too lazy to mess with.
CaniacNation is offline   Reply With Quote Quick reply to this message
Unread 09-05-2012, 07:33 AM   #11
XJ2WK2
2011 WK
Sorry to highjack this thread
I am having my lift installed tomorrow, and want some taller tires to use until winter.
I have searched the wheel encyclopedia, wheel and tire sizes gallery and the picture thread, and used google with no definitive answer.
Will these wheels/tires off a 2012 JK work? I know the 18's work, several guys have used them, and I know the 17's off the rubicon work, but couldn't find any examples of this wheel being used.
Thanks guys, and sorry again about the highjack, didn't deserve it's own thread!
XJ2WK2 is offline   Reply With Quote Quick reply to this message
Unread 09-10-2012, 11:53 AM   #12
DirtyTires
2011 WK
Specs:
ATX188 Ledge
Wheel Size: 18x9
5 on 5 Bolt Pattern
Offset: 0
Backspace: 5
Sorry to reply so late, but that's exactly the wheel I have on mine, pics are in this thread:
http://www.jeepforum.com/forum/f309/2011-wk2-1363156/
2011 Laredo X 4x4, ORA 1, Quad Trac II 4WD, Wild Country XTX Sport 265/70/17, American Racing ATX series AX188 Ledge, RRO 2.5 lift, PIAA 510 & 520 ATP Aux lights, Yakima roof rack, Mopar rock rails, dealer OEM hitch, RR winch mount and brush bar, Smitty 10K winch, RR pre-runner skid plate, slightly de-chromed.
DirtyTires is offline   Reply With Quote Quick reply to this message
Unread 09-18-2012, 07:23 PM   #13
JasonJasoff
2012 WK
Went with a set of 18" XD Addicts machined. And BF Goodrich All-terrain 275/65.
image-3375217860.jpg   image-4197859714.jpg   image-3916470040.jpg   image-1196593492.jpg
Unread 09-18-2012, 07:44 PM   #14
Big50
2012 WK
Looks great! Amazing what a 0 offset wheel and more aggressive tire can do for the looks of these Jeeps.
2012 Laredo X 4X4, 5.7 Hemi, luxury package. Mods: 2.5" RR lift, ProComp 7036 wheels, 275/65-18 Wrangler Duratracs. Pics in my gallery
Mild wheeling in my WK2: http://www.youtube.com/watch?v=AueMXQvqCBE&list=UUzGUjoJwwUpCb5Ea05FVtPw&index=2&feature=plcp
Big50 is offline   Reply With Quote Quick reply to this message
Unread 09-22-2012, 11:30 PM   #15
JasonJasoff
2012 WK
+18 offset, but agreed!
