Help! 2012 Laredo check engine light on. What dealer tells me today is true? - JeepForum.com
post #1 of 8 Old 11-23-2011, 01:38 AM Thread Starter
seaflow
I bought a new 2012 Laredo three days ago.
Yesterday I just notice that: "check engine light" (of instrument panel) is always on if the key is put on an "ON" position without starting engine.
Today afternoon, I ask the dealer the reason. He tells me this is exactly how it is supposed to be. Is what he says true?
The whole issue is like this:
(1) On Ignition Switch, there are four positions: "OFF", "ACC", "ON", and "START". When I insert a key and turn it from "OFF" to "ON", the check engine light turns on and stays on steadily.
(2) Then, when I turn the key to the "Start" position to start engine, the engine gets started and the "check engine light" turns off.
Is what dealer says true? If not, what may be the problem?
Thanks for your expert comment!
seaflow is offline
post #2 of 8 Old 11-23-2011, 07:01 AM
tjkj2002
2002 KJ Liberty
What the dealer say's is true.
tjkj2002 is offline
post #3 of 8 Old 11-23-2011, 08:14 AM
fljeepleo
2011 WK
No push button start? My Laredo E came with push button start.
2011 Stone White Grand Cherokee Laredo E, ORA1, QT2, Factory Trailer Tow, 3m FX 15% Tint.
Retired Jeeps
1998 Wrangler Sahara 10inch skyjacker lift, 38x14.50 TSL
2005 Grand Cherokee Limited, 5.7, QD2
fljeepleo is offline
post #4 of 8 Old 11-23-2011, 09:15 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
EPA wants all or most of the bulbs checked routinely, so manufactures often illuminate all or most of the idiot lights in the on/run position. That position turns both the engine and accessories on. If you don't intend to run the engine, use the accessory position. Think in terms that the "on" term here is in reference to the engine. If you turn the engine on and it is not running, then there may be a problem. So alert the driver with an idiot light.
ColdCase is offline
post #5 of 8 Old 11-23-2011, 07:40 PM
rudeney
2014 WK
This is a federally mandated function of the OBDII system. The MIL must remain illuminated for at least 20 seconds when the engine is not running and the ignition switch is in the "run" position (accessible via the second press of the START button without the brake pedal depressed). This is required to verify its operation. If the MIL did not illuminate in this situation, there would be no way to know if the light was functioning or not. The bulb could be burned out and it would then be assumed that everything is operating proper. All OBDII compliant vehicles (mandated as all vehicles built since January 1996) operate this way.
rudeney is offline
post #6 of 8 Old 11-24-2011, 02:19 AM
FlyinJeep
What he said...In fact in some states (NC is this way) if the check engine light does not illuminate with the engine off and switch to "on" your vehicle will fail the emission inspection. This is used to verify that the light is not burned out or tampered with to hide a fault condition.
FlyinJeep is offline
post #7 of 8 Old 11-27-2011, 02:56 AM Thread Starter
seaflow
When I insert a key and turn "Ignition Switch" to the "ON" position without starting engine, my concern is: all other lights flash for a short while and automatically turn off, except this "check engine light" (that turns on and is always on).
When my engine gets started, I do see the "check engine light" become off.
So is the "check engine light" a concern on the new 2012 Laredo?
seaflow is offline
post #8 of 8 Old 11-27-2011, 06:26 PM
rudeney
2014 WK
No, this behavior is nothing to be concerned about. It's perfectly normal. As long as the light is not on after the engine has been started, there are no problems.
rudeney is offline
Dealer mentioned Manufacturer-to-Customer rebate on Jeep 2012. Is it true? seaflow WK2 Grand Cherokee Forum 15 11-18-2011 01:02 PM
2012 GC Laredo X Check Engine Light on dereksy WK2 Grand Cherokee Forum 3 11-16-2011 08:58 PM
Is "Laredo E group" a removable option in GC 2012? Dealer says no. seaflow WK2 Grand Cherokee Forum 6 11-01-2011 08:35 PM
2 Check engine lights and the dealer finally fixes the "known" defect albnyblows WK2 Grand Cherokee Forum 9 10-21-2011 09:14 AM
Check engine on 2011 Jeep Grand Cherokee Laredo Davidson881 WK2 Grand Cherokee Forum 4 01-16-2011 08:23 PM
