heated seat issue - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > heated seat issue
15 x 8 Black D-Window Steel Wheels Set of 4Magnaflow SS Cat Back Exhaust System, Street, High ClearanRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Unread 10-24-2011, 02:11 PM   #1
WvTaco
2011 WK
heated seat issue
has anyone ever had this issue with the heated seats? watch video.
http://s227.photobucket.com/albums/d...urrent=021.mp4
this is the second time, since i have bought it that it has done this.
if i stop and turn off the car then restart it it corrects itself.
WvTaco is offline   Reply With Quote
Unread 10-24-2011, 05:22 PM   #2
Ungerer
Take it back to work shop ;( and get it looked at
Ungerer is offline   Reply With Quote
Unread 10-24-2011, 06:52 PM   #3
oldmac1
2014 WK
I'd take it back to the dealer along with the video so that can't say it does not fail for them and that you don't have a problem. Sometimes the hardest part of getting something fixed is proving that there is a issue. Good luck.
Oldmac1
14 GC Overland
12 Liberty
08 Rubicon Unlimited
oldmac1 is offline   Reply With Quote
Unread 10-25-2011, 06:14 AM   #4
LuckRider
LuckRider's Avatar
Yep, we had the exact same issue. They ended up replacing the heating pads and they now work perfectly and as described in the manual. Good luck with the fix. It shouldn't be much of an issue.
Support Our Troops!
ALL WK2 Owners, Click Here
JFI Member #7: Helping out the Scammed
2004 Rubi: Ready to Kill the Chrome!
Totaled and Gone: Mostly Stock 2005 I6 Patriot Blue TJ: Monstaliner (Write-Up) BESRK Rear Bumper, Hella 500s
LuckRider is offline   Reply With Quote
Unread 10-26-2011, 02:03 PM   #5
WvTaco
2011 WK
next time i go by the dealer i will tell them about it. but the dealer is about 70-80 miles away so i will wait till it is convenient for me....
kinda glad to see i am not the only one who this has happened to. not really glad but u know what i mean.
Unread 01-17-2012, 08:14 PM   #6
poberlies
I had the same issue with my driver's side seat. It started happening six weeks after I bought my Jeep. On the high setting, it would stay on for 10 to 15 minutes, then shut off. The only way to get the seat to come back on (for 10 to 15 minutes) was to turn off the vehicle then turn it back on. Having it on the low setting worked fine.
There was a problem with the left heater control circuit. They said the circuit resistance was out of range. They replaced the driver side heater element in the seat back. Since then, I'm happy to report it is working fine.
poberlies is offline   Reply With Quote
Unread 01-18-2012, 11:21 AM   #7
Testudo
2012 WK
Just had the exact situation occur on the way to work Monday. It happened on the coldest day around here so far this winter, ~12F. The passenger side was fine. When I started the vehicle to come home from work it was working fine. Has not happened again. I plan on heading to the dealer and will use your video as a visual aide (so thanks for posting!).
Testudo is offline   Reply With Quote
Unread 03-25-2013, 09:51 AM   #8
AbnWK2
2011 WK
I just took my 2011 WK2 to the stealership for this exact thing. They will replace the heating element (still under warranty) so I hope this works. I will post again in a week or so with results.
AbnWK2 is offline   Reply With Quote
Unread 03-28-2013, 09:59 AM   #9
WvTaco
2011 WK
fixed my issue. had the passenger side do it once but now 6 months later it hasnt done it again.
Unread 10-22-2013, 07:53 AM   #10
WvTaco
2011 WK
pass side is doing the same thing, got an appt friday to get it checked out.
jeep 0 for 2 on heated seats. at least it is still under warranty.
