Headlight upgrade - JeepForum.com
post #1 of 6 Old 08-20-2017, 04:29 AM Thread Starter
joshbarnett
Headlight upgrade
I was wondering if the headlight upgrade on a 2015 Laredo is as straightforward as just swapping the headlights or you have to get different wiring as well.
Here is what I'm talking about. I want to go from these stock headlights:
To these HID ones:
How involved is the swap?
joshbarnett is offline
post #2 of 6 Old 08-20-2017, 05:53 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Been lots of discussion on the details, if no one jumps in here you should be able to find something current. The easiest, and probably least expensive method, may be to trade your Jeep in on one with the headlights you want
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #3 of 6 Old 08-20-2017, 07:10 AM
brutusjeep
2014 WK
It's a software issue that will not allow you to simply swap the headlights.
2014 - Summit
Sold - 2006 GC Limited, 5.7L HEMI, Quad II. 4XGUARD Belly & Front (black powder coat) skid plates. Matrix front guard, PIAA Matrix mounted lights, 265/70 Nitto Trail Graplers MT, 1.5" Spider Trax spacers, Super Chips Tuner, OME MD Lift, 4XGUARD differential guard, JBA UCA'S.
brutusjeep is offline
post #4 of 6 Old 08-20-2017, 08:01 PM
brsox88
2014 WK
It's not a software issue, its a wiring harness issue that is different. If you look up the recent threads on here there is a guy that sells the wiring harness for $450.
brsox88 is offline
post #5 of 6 Old 08-21-2017, 01:21 AM Thread Starter
joshbarnett
Makes sense. Thank you.
post #6 of 6 Old 08-21-2017, 05:18 AM
ColdCase
ColdCase's Avatar
2011 WK
Well its both hardware and software, but the adapter harness seems to adapt close enough.
