Has anyone upgrade stock low beam to LED light? - Page 2 - JeepForum.com
post #16 of 20 Old 05-02-2013, 03:03 PM
doz
2012 WK
HIDs will install just fine in the headlight housings. I havent done it myself yet (although plan to), but very little modification is usually needed to adapt in a HID. I know on my 2010 Ram, it was all plug and play pretty simple. On the reasoning of illegal, like stated above, installing LED bulbs are illegal as well as far as I know. Also, HID output is far greater than LED at this time. From my research, LED kits are around 40-50% less lumens than HID.
Regardless, if you want more light output you should goto HID. If you are looking for a little better spectrum and color change, just get some Silverstars. I see no reason to use LED lighting at this time considering a high quality custom job will run you a buttload and a cheap kit is about the same as a high quality HID kit.
doz is offline
post #17 of 20 Old 05-02-2013, 03:21 PM
97HMCS
2012 WK
LED's will most likely be the standard for future headlights.
I used these LED's http://shop.predatorinc.com/h1ledheadlampset.aspx on my Hummer. Great light output, but they didn't produce enough heat to melt ice and snow.
97HMCS is offline
post #18 of 20 Old 05-02-2013, 03:42 PM
tjkj2002
2002 KJ Liberty
My LED lightbars put some heat out and my 30watt LED flashlight(one 30watt LED chip) could boil water after being left one for 30mins straight.
tjkj2002 is offline
post #19 of 20 Old 05-02-2013, 03:44 PM
loveracing1988
I you can afford a h1 hummer, you can afford to spend $800 in headlights.....
loveracing1988 is offline
post #20 of 20 Old 05-02-2013, 04:03 PM
97HMCS
2012 WK
I don't think the flashlight would work on the Hummer
97HMCS is offline
