Hard brake pedal before starting - JeepForum.com
post #1 of 10 Old 08-20-2013, 08:52 PM Thread Starter
bikerbill7
I've seen the thread regarding a hard brake pedal while driving. But I occasionally experience a hard brake pedal BEFORE starting my 2011 Limited 5.7. The brake pedal is never hard while driving, and it's only hard before starting after the vehicle has sat in the garage for a couple / few days. After the motor starts, the pedal goes down to normal "power-brake" feel. Any thoughts as to what's going on?
bikerbill7 is offline
post #2 of 10 Old 08-21-2013, 05:45 AM
Gran_Paradiso
2015 Summit
Gran_Paradiso's Avatar
2015 WK
I have the same thing happen. Been reading on this forum its common and normal. This is the first vehicle I've owned that has done this though.
Gran_Paradiso is offline
post #3 of 10 Old 08-21-2013, 06:13 AM
Jpiwonski
2011 WK
My 11 does it every so often as well.
Jpiwonski is offline
post #4 of 10 Old 08-21-2013, 06:17 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
My 2011 pedal is hard all the time before starting.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #5 of 10 Old 08-21-2013, 06:42 AM
jacko15
2014 WK
My '14 is the same way. I believe it is normal.
Hers: 2008 Jeep Compass Sport
Mine: 2014 Jeep Grand Cherokee Overland V/6 ORA II
Michelin LTX M/S 2's
jacko15 is offline
post #6 of 10 Old 08-21-2013, 06:44 AM
tjkj2002
2002 KJ Liberty
Normal since you do not have any vacuum assist with the engine off.
Start the engine,run for a 30 seconds,turn off engine.Pump the brake pedal,you will notice it gets harder as the vacuum in the booster is drained.
tjkj2002 is offline
post #7 of 10 Old 08-21-2013, 09:06 AM Thread Starter
bikerbill7
I understand the vacuum issue, but this is the first vehicle I've owned that has done this in my 40 years of driving. Thus the question, why?
post #8 of 10 Old 08-21-2013, 11:07 AM
ColdCase
ColdCase's Avatar
2011 WK
A hard pedal is typical (for most brands) when all or most of the vacuum has been released from the booster before the start. There is a check valve that retains booster vacuum after shutoff, but these systems leak a bit regardless. You will see similar comments on other forums, typically BMW. From vehicle to vehicle, the vacuum leaks away at different rates, but it does leak over time. If you have a bad check valve, it may release the vacuum sooner than later.
My 2000 Jeep WJ had a hard pedal before start, I think also the 2006 Ram, but not as firm as the WK2.. my 2009KK not so much. I haven't thought of it as being unusual, but the feel may be different than other makes and models.
ColdCase is offline
post #9 of 10 Old 08-21-2013, 03:17 PM
steveinaz
2011 WK
My 2011 laredo has done this from day 1, it's a non-issue, looking for a solution.
2011 Grand Cherokee Laredo 4X4
3.6L V-6 with Selec-Terrain
Off-Road Adventure package
Tow package
steveinaz is offline
post #10 of 10 Old 08-21-2013, 06:50 PM
BobsWK2
2014 WK
My 2014 sometimes (while parked) retains the vacuum for 5-6 days, othertimes it loses vacuum overnight. Doesn't say much for quality since it isn't consistant.
2014 Summit 4X4 V8
BobsWK2 is offline
