GPS Antenna - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > GPS Antenna
Smittybilt Hard Tops @ Oconee Off-Road! 706-534-9955XHD Heavy-Duty Hood Latches for JK and TJ available at OcoFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 05-05-2014, 07:57 AM   #1
KUBU
2014 WK
Wk GPS Antenna
I am getting my Jeep GC '14 tinted from VKool and they use metallic films. Can someone tell me if it will affect the GPS connectivity? I am told that GC '13 has this problem.
Is the antenna outside for '14 (on the top) or inside the car?
GC '14 Overland 5.7 V8
KUBU is offline   Reply With Quote
Unread 05-05-2014, 09:45 AM   #2
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
The factory GPS and sat antennas are in the base of the external antenna on the roof. Dealer or add-ons typically have the GBS antenna under the dash near where the center speaker is.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote
Unread 07-16-2014, 09:56 AM   #3
billybob123
2011 WK
Coldcase
Getting back to my bending question on the other thread . I would lose my navagation also if I just disconnect the antenna ?
Could you or anyone here point me to somewhere that sells a stubby antenna ?
Are they easy to put on ?
billybob123 is offline   Reply With Quote
Unread 07-16-2014, 11:01 AM   #4
ColdCase
ColdCase's Avatar
2011 WK
No, the stubby only effects AM and FM, its just a wire wound around a flexible rubber form.
I bought a mangowalk 5" stubby for the KK off ebay. Some of them are universal fit in that they have a couple fittings to fit a wide variety of vehicles.
http://www.ebay.com/sch/Car-Truck-Pa...erokee%7E-%7E-
Unread 07-16-2014, 11:06 AM   #5
jimb0JP
Amazon also sells the stubby antennas...$25 and free shipping. http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
2012 Jeep Grand Cherokee Altitude 5.7
2002 Pontiac Trans Am Firehawk
1991 Pontiac Formula Firehawk
jimb0JP is offline   Reply With Quote
Unread 07-16-2014, 11:52 AM   #6
billybob123
2011 WK
Well it looks like the stubbys are still 4 1/2 " .
Shark fin would be lower profile unless there is a " shorter" stubby version ?
Unread 07-16-2014, 12:27 PM   #7
bocajrs
2012 WK
I bought the stubby. Not as low profile as the shark antenna, but better than OEM. So far so good
bocajrs is offline   Reply With Quote
Unread 07-16-2014, 12:45 PM   #8
ColdCase
ColdCase's Avatar
2011 WK
1 1/2 and 3 inch stubbies are available in rubber, some are cut to fit.. all these have less effective AM/FM reception. Not sure off hand what the thread size is for the WK2. Most stubs are sold by thread size, or have adapters.
The shark fin is lower, I think it sticks 2 1/2 to 3 inches above the roof line.
Unread 07-17-2014, 07:28 AM   #9
jimb0JP
Here's a pic of the Shark Fin antenna. It's pretty low profile compared to the alternatives, and is about 1/2" taller than the stock antenna base without the mast attached.
BTW, AM/FM reception is very good with this antenna...at least equal to that with the OEM antenna.
