Glove Box Removal WK2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Glove Box Removal WK2
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitLong Arm kits for all JK models from Clayton Off RoadFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 04-03-2014, 08:41 AM   #1
nubby105
2011 WK
I removed the glove box to change the Cabin Filter. The cable that holds the glove box came undone from somewhere, but I don't know where the cable should be attached or how. (not the side that attaches to the glove box itself)
Thanks in advance
nubby105 is offline   Reply With Quote
Unread 04-03-2014, 09:17 AM   #2
97HMCS
2012 WK
The cable would attach to the damper mechanism located behind the slot that is visible just below the filter. I have no idea how to reattach the cable to the damper.
97HMCS is offline   Reply With Quote
Unread 04-03-2014, 06:49 PM   #3
BobsWK2
2014 WK
The damper mechanism is removeable. You will see to slots which the damper attaches to. Just slide the damper to the side and it pops off. Put the glove box door cable back on the damper and then reattach the damper.
2014 Summit 4X4 V8
BobsWK2 is offline   Reply With Quote
Unread 04-04-2014, 10:04 AM   #4
97HMCS
2012 WK
That's good information. Thanks for sharing.
Unread 04-04-2014, 03:43 PM   #5
bocajrs
2012 WK
I replaced the cabin filter on my wk2 without any issues - I found this site and YouTube helpful
http://www.paulstravelpictures.com/J...acement-Guide/
bocajrs is offline   Reply With Quote
