GC stalled on highway - JeepForum.com
post #1 of 8 Old 11-28-2015, 02:28 PM Thread Starter
dawgn86
Please any suggestions---2012 Jeep GC Laredo...v8 Hemi...60000 miles
about a month ago, we had the fuel relay recall done at a dealer; next day car wont start. Dealer towed it in and refixed it.
Today, driving down the highway, it suddenly just quit after traction control light came on. This in on major interstate north of Atlanta. After a few minutes they car started and they drove it to next exit for safety and tow truck on its way.
The dealer just changed the oil yesterday and today this...
any suggestions?
dawgn86 is offline
post #2 of 8 Old 11-28-2015, 05:56 PM
Blackshirts
2012 WK
What did the dealer "Re-fix"? Did they admit the recall work on the fuel pump relay wasn't correct of the parts failed"
Blackshirts is offline
post #3 of 8 Old 11-28-2015, 07:01 PM Thread Starter
dawgn86
Blackshirts...I will find out Monday...just seems an odd coincidence the day after they changed the oil, this happens.
dawgn86 is offline
post #4 of 8 Old 12-03-2015, 08:31 AM Thread Starter
dawgn86
Hi,
So I got my GC back yesterday from the dealer...it was a "loose connection" in the TIPM module.
Can someone give me some guidance as to what the TIPM does, why would there be loose connections..is this a common problem?
Thanks
dawgn86 is offline
post #5 of 8 Old 12-03-2015, 08:55 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Its not unusual to have a TIPM connection problem after the recall. They have to do surgery on one of the connectors. The TIPM basically is a computer that takes in commands from other modules and powers things up/down, and monitors current draw... like fuel pumps, starters, lights...
"The Totally Integrated Power Module (TIPM) is a combination unit that performs the functions of the Power Distribution Center (PDC) and the Front Control Module. The TIPM is a printed circuit board based module that contains fuses, internal relays and a microprocessor. The TIPM is located in the engine compartment next to the passenger side strut tower. The B+ cable connects directly to the TIPM via a stud located on top of the unit. The ground connection is via electrical connectors. The TIPM provides the primary means of voltage distribution and protection for the entire vehicle.
The molded plastic TIPM housing includes a base and cover. The TIPM cover is easily opened or removed for service and has a fuse and relay layout map integral to the inside surface of the cover. The TIPM housing base and cover are secured in place via mounting tabs. The mounting tabs secure the TIPM to the TIPM mounting bracket.
All of the current from the battery and the generator output enters the Totally Integrated Power Module (TIPM) via a stud on the top of the module. The TIPM cover is removed to access the fuses or relays. Internal connections of all of the power distribution center circuits is accomplished by a combination of bus bars and a printed circuit board. "
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #6 of 8 Old 12-04-2015, 10:17 AM Thread Starter
dawgn86
Coldcase..no disrespect intended, but that doesnt seem unusual to me, especially when its your daughter stalling on a major interstate in Atlanta doing 75mph...seems like a cheap way out for the dealer.
dawgn86 is offline
post #7 of 8 Old 12-04-2015, 10:28 AM
ColdCase
ColdCase's Avatar
2011 WK
You asked if it was a common problem. I have seen several reported here, so its not unusual in my opinion, but it does seem to be relatively rare. On mine, they blew out a fusible link. I didn't mean to imply anything about how critical or serious the situation is, just that it happens.
ColdCase is offline
post #8 of 8 Old 12-08-2015, 06:38 AM Thread Starter
dawgn86
Got it back and seems to be doing fine for now.
dawgn86 is offline
