FYI - Service Bulletin 26-004-12 - 2011-2012 Fluid Flushing Requirements - JeepForum.com
post #1 of 17 Old 06-06-2012, 08:52 AM Thread Starter
JeepCares
FCA Customer Care
JeepCares's Avatar
Ignore if not interested.
BULLETIN NUMBER: 26-004-12
DATE: June 06, 2012
SUBJECT:
MODELS:
2011 - 2012 (JK) Wrangler
2011 - 2012 (KK) Liberty
2011 - 2012 (MK) Compass/Patriot
2011 - 2012 (WK) Grand Cherokee
DISCUSSION:
Chrysler Group vehicle fluid systems do NOT require regular flushing. These systems include: engine oil, transmission oil, axle lube, brake fluid, power steering fluid, and refrigerant. The only exceptions to this requirement are published in the vehicle maintenance schedules, e.g. engine coolant.
Exceptions to this recommendation include only those instances where a malfunction has occurred and/or the system has become compromised, contaminated or overheated beyond the normal operating range.
Chrysler Group does NOT recommend aftermarket chemicals to flush the engine, transmission, brake or steering systems. Chemicals contained in these products can damage the system elastomeric components, and contaminate the component fluid, leading to loss of system/component durability and service life. When necessary, only the original approved system fluid should be used to flush these components using teamPSEŽ approved equipment.
If the engine coolant contains a considerable amount of sediment, clean and flush with Mopar Cooling System Flush, p/n 04856977, or equivalent. Follow with a thorough rinsing to remove all deposits and chemicals. Refill with a minimum of a 50% mixture of the specified coolant and distilled water.
JeepCares is online now
post #2 of 17 Old 06-06-2012, 02:50 PM
SPL170db
So keep the original engine oil that the truck came with in there right? Should I at least replace the filter?
SPL170db is offline
post #3 of 17 Old 06-06-2012, 03:06 PM
Webb
Webb's Avatar
2012 WK
Originally Posted by spl170db View Post
so keep the original engine oil that the truck came with in there right? Should i at least replace the filter?
x2
2012 Limited 4X4 Hemi,Maximum Steel Metallic ,730n & 20's.Average 9K's a year.
Webb is offline
post #4 of 17 Old 06-06-2012, 03:19 PM
97HMCS
2012 WK
Obviously, change all fluids at the specified intervals.
"Flushing" is not required/recommended.
97HMCS is offline
post #5 of 17 Old 06-06-2012, 04:34 PM
SPL170db
lol
SPL170db is offline
post #6 of 17 Old 06-06-2012, 05:13 PM
RageOfFury
2014 WK
Flushing is never a good idea anyway so kudos to Chrysler for coming out with this.
Of course fluid like engine oil and transfer case oil are to be CHANGED as per the owner's manual. Just no flushing.
Thanks Lee!
RageOfFury is offline
post #7 of 17 Old 06-07-2012, 06:18 AM Thread Starter
JeepCares
FCA Customer Care
JeepCares's Avatar
It might actually save some people some money if they follow the manufacturer's recommendations and not just going along with something that someone is trying to sell them.
post #8 of 17 Old 06-07-2012, 06:38 AM
MaineJeep11
2011 WK
This is helpful, Thanks. It would also be nice if Jeep didn't allow it's dealers to try and pressure you into doing all these "flushes" and putting extra, expense additives in oil, transmission fluid, etc.
2011 Laredo V6, OR1, RR 2.5" lift, ProComp 7036 wheels, 265/70/17 Toyo Open Country AT's - SOLD
MaineJeep11 is offline
post #9 of 17 Old 06-07-2012, 07:02 AM Thread Starter
JeepCares
FCA Customer Care
JeepCares's Avatar
That is something we are trying and have been trying to address. It makes the cost of ownership higher than it actually needs to be.
One reason reason I posted the information was to make people aware of what the MANUFACTURER recommends. Also, you might also have seen posts where I stress to people to follow the MANUFACTURER's maintenance recommendations in the Owner's Manual.
post #10 of 17 Old 06-07-2012, 07:20 AM
Kev M
2012 WK
I haven't checked the maintenance schedule closely yet, but I ASSume Brake Fluid CHANGES are still recommended. Yes?
Kev M is offline
post #11 of 17 Old 06-07-2012, 07:55 AM Thread Starter
JeepCares
FCA Customer Care
JeepCares's Avatar
I am confused a little bit by this question. The word "still" makes me think at one time brake fluid changes were recommended as part of regular maintenance. To be honest, I don't remember this. Maybe some of the more experienced members of the forum might chime in.
Changing the brake fluid just to change it, is not part of the regular maintenance schedule for a 2012 WK. You might have to add fluid - or even replace it as part of a repair. I suppose if the fluid was contaminated you would change it, but I wouldn't consider that "regular" maintenance.
post #12 of 17 Old 06-07-2012, 08:08 AM
MaineJeep11
2011 WK
It's great that Jeep is trying to address that with the dealers. It's difficult for consumers when you try to follow the manufacturer maintenance recommendations, but the service advisors lie to you and make you feel as though you're doing something wrong, voiding your warranty, etc. for not doing the "extra" stuff they recommend. Especially people who aren't savvy. Thank you for addressing this issue, it's great to hear. And thanks for these kinds of posts as they're helpful.
post #13 of 17 Old 06-07-2012, 08:32 AM
Ben
When will we be able to get an actual factory service manual with real information, instead of the lame CYA document that's in the glove box?
Ben is offline
post #14 of 17 Old 06-07-2012, 09:54 PM
Heath
2014 JK Wrangler
Brake fluid can break down from heat or from moisture introduction.
2013 JKU Rubicon
Heath is offline
post #15 of 17 Old 06-08-2012, 07:48 AM Thread Starter
JeepCares
FCA Customer Care
JeepCares's Avatar
Obtaining Service Manuals / Owner's Manuals
Service manual information can be obtained at http://techauthority.com.
The original owner of all Jeeps receive an Owner's Information Kit in their 2010 and up model year vehicle at time of delivery.
The kit contains the a printed User Guide and a DVD containing electronic copies (PDFs) of the Owner's Manual, Navigation Radio or Multi-Media Radio Manuals, Warranty Information book, Tire Warranty, and 24-Hour Towing Assistance information.
If the FIRST registered retail owner or retail lessee of a 2010 and up model year requests a PRINTED copy of the Owner's Manual, Navigation Radio, Multi-Media Radio Manual, and the Warranty Information book, one complimentary copy will be shipped direct to the customer in 2-3 weeks.
To contact Jeep to obtain a printed manual, call 877-IAMJEEP (877-426-5337).
You can download a free owner's manual (model year 2004 and up) at http://www.jeep.com/en/owners/manuals/.
Service Manual WK2 2011-2012 padgett WK2 Grand Cherokee Forum 21 10-05-2016 09:10 AM
Purchase Decisions 2011-2012 WK2 Multi-G WK2 Grand Cherokee Forum 18 05-08-2012 11:04 AM
2011 (WK) Grand Cherokee (International Markets) - Service Bulletin 26-002-12 JeepCares WK2 Grand Cherokee Forum 0 03-16-2012 08:16 AM
GC 2012 Factory Service Manual Schnappi WK2 Grand Cherokee Forum 6 11-29-2011 02:46 PM
2011-2012 WK2 V6 questions (mainly towing) User_22 WK2 Grand Cherokee Forum 13 11-11-2011 11:23 PM
