Fueleconomy calculator - JeepForum.com
post #1 of 9 Old 05-13-2013, 05:22 PM Thread Starter
gtanty
I have a bit over 10,000 miles on my '12 Limited. I have never reset the fuel economy calculator, or trip mileage. So I thought that the fuel economy it was showing me was all time since I acquired the vehicle. That showed 17.0. Most of my driving is local. I just got back from a 1,000 mile trip, most of which was on highways and Interstates. My economy now shows as 21.3. I guess I find it hard to believe that one 1,000 mile trip can improve all time economy by that much.
Was the 17 mpg before the trip really the average number since I first got the vehicle? Should one highway trip make that much of a difference?
Thanks all
George
gtanty is offline
post #2 of 9 Old 05-13-2013, 05:46 PM
shekshishekki
2013 WK
Sounds about right... They might have a limited interval for these calculations.
shekshishekki is offline
post #3 of 9 Old 05-14-2013, 04:22 AM
97HMCS
2012 WK
Apparently, not a true running average. It does sound more like a limited interval.
Average was 17 MPG, now 21.3 might be calculated as follows:
Let's say your 1000 mile highway trip averaged 25 MPG: 25 + 17 = 42 divided by 2 + 21 MPG.
This is only a wild guess since I have no clue how the running average actually works.
97HMCS is offline
post #4 of 9 Old 05-14-2013, 07:49 AM
jim_in_PA
2012 WK
As folks have mentioned, the fuel economy display is a running average with a "window" of x miles. So yes, a 1000 mile highway trip will get you to where you are more-or-less showing what your highway mileage was since the "window" is undoubtedly lower than 1000 miles in my experience. The accuracy can vary slightly from "real" hard-measured fuel economy, depending on how you drive. I have a light foot and my EVIC mileage has actually been pretty close to "real" based on my spot checks using a calculator and fuel recepts. I'm also showing 17 for my general rural driving right now; slightly higher than it was because with the milder weather, I'm running with the HVAC on manual with just outside air blowing in. Highway, I get about 20-21 manually calculated as well as via the EVIC.
• 2012 JGC Summit Hemi
• 2016 Subaru Outback Limited
• 2011 Subaru Outback Limited
jim_in_PA is offline
post #5 of 9 Old 05-14-2013, 08:49 AM
LibGrandCher
2012 WK
I had a similar experience.
I think your numbers are reasonably accurate.
I just did a road trip from Toronto Canada to Lawrence Indiana USA.
EVIC read 12 MPG at start of the trip and 23 MPG at the end. I stopped 3 times along the way.
Did the same trip in the wife's 2 door, 2 liter Hyundai had almost the same numbers
LibGrandCher is offline
post #6 of 9 Old 05-14-2013, 11:17 AM
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Sounds right to me. On a 2600 miles round trip from Houston to Durango, I went from 17 MPG in Houston to 22.5 once I hit Dallas a few hours after leaving.
2011 Billet JKUS
Jackal01 is offline
post #7 of 9 Old 05-14-2013, 11:45 AM
kkreit01
I reset mine every tank...always have for every vehicles that has had this feature.
kkreit01 is offline
post #8 of 9 Old 05-14-2013, 01:21 PM
97HMCS
2012 WK
I like Swiss cheese, but the price keeps going up.
97HMCS is offline
post #9 of 9 Old 05-15-2013, 06:07 AM
JeepJeep2012
2012 WK
The MPG will creep up and I would think that a 1000 mile trip would be far enough to raise it to 21 mpg. I know that when on the hwy driving the speed limit or a little above and not passing a lot I will always get 24+ mpg (V6) and around town I get between 18 & 21. I think the GC gets pretty good mileage considering what you are driving. There are a lot of lesser vehicles out there that don't get all that much better mileage!
JeepJeep2012 is offline
