First Tire Rotation 2015 JGC Overland - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > First Tire Rotation 2015 JGC Overland
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep seats at Jeephut.comEngo winches available at www.rockridge4wd.com! Free shipp
Unread 01-31-2015, 06:50 PM   #1
lurtonk
Drive it like u stole it
2015 WK
Wk First Tire Rotation 2015 JGC Overland
I did the first tire rotation today.
6k miles, 4 wheel rotation.
I didn't have my keys so I did put quadra-lift in "tire change mode" so there was a lot of raising and lowering of the suspension while I was moving the tires.
I jacked up RR and put a jack stand, then RF, LR, LF so as I moved around I could here the suspension pump operating.
It didn't bother me but i can see why you should put it in the correct mode before fixing a flat especially on an uneven surface.
By the time I was finished, quadra-lift was back in Entry/Exit mode.
lurtonk is offline   Reply With Quote Quick reply to this message
Unread 01-31-2015, 06:57 PM   #2
TJSport97
2014 WK
Did mine two days ago, 6000 miles as well. I did put my air suspension in "jack" mode but still a pretty high lift. I use my spare instead of a jackstand. Good time to check the pressure in it too.
Have a nice day. Gary
TJSport97 is online now   Reply With Quote Quick reply to this message
Unread 01-31-2015, 07:36 PM   #3
perpster
2015 WK
What rotation pattern did you use?
perpster is offline   Reply With Quote Quick reply to this message
Unread 01-31-2015, 07:52 PM   #4
TJSport97
2014 WK
Moved the rears straight to the front and crossed the fronts to the rear. That's the recommended rotation for a rear/4wheel drive vehicle.
Unread 01-31-2015, 08:16 PM   #5
lurtonk
2015 WK
Wk
"Forward-cross" sequence as defined in owner's manual.
RightRear to RightFront to LeftRear to LeftFront to RightRear
